RS master cylinder in Dx hatch with stock brakes...
Obviously it is advised to get the RS master cylinder when you get GSR or equivilent brakes, but will it help with stock brakes? Id assume it will still give you more braking power, but.... anyone know? Thanks!
-Nick-
-Nick-
it will give you more brake power your DX master cylinder is a 13/16" and a GSR master is 1" so you will get better braking power but you will also need a Brake booster for what ever master you use
if you are changing the master cylinder change the booster also. i can get you both if you want. the answer is yes stopping power will be better
adrian1281
Aug 23, 2003 09:43 PM
