fully loaded mechanics tool box for sale
im asking $3800 for this box and tools, there is alot more than $3800 in tools in it, im no longer a mechanic and for the minor work i do on my car it does not pay to have these sitting around...
im sure someone can meake good use of them
tool included:
13mm-27mm 1/2dr. deep impact socket set husky
10mm-27mm 1/2dr. shallow impact socket set Mac
T10-T60 torx reg style Mac
T10-T60 torx new style Mac
10mm-19mm 3/8dr. impact swivel Mac
adapter set (mostly mac) includes all even 3/4 ->1/2
10mm-22mm 3/8dr shallow impact socket set Mac
8mm-21mm 3/8dr deep impact socket set Mac
2ft pry bar Mac
42in pry bar Mac
1/2dr breaker bar Mac
Misc bolt drawr (lots of h/a bolts)
mini screw driver set
shrink wrap
electrical tape
center punch / scribe
4 misc allen key setes mis brands and mis allen keys
4 tire guages
a squeegee for tint/vinyl
markers
misc air impact fittings
screw driver drawr... has just about everything... snap on, cornwel, mac, stanley, craftsman mostly
mac pick tool (most handy thing ever)
SK wrench set 10mm-22mm and an adjustable wrench
1/2dr craftsman ratchet
1/2dr craftsman breaker bar 14inch
titan 3/8 1/4 stuby ratchet
no name 3/8 ratchet
2 craftsman 1/4 ratchests
3/8 snap on ratchet
3/8 mac ratchet long handle
all extentions included 1/4 3/8 1/2 1inch 3inch 6inch 9inch yada yada
2 noname crimp tools and wire ends
blue point crimp tool
8mm-19mm flex head ratcheting wrenches bought from mac tool truck
wire stripping tool
mac test light
misc fuess
diaeletric grease
contact cleaner
noname test light
ground straps power wires 4 awg 8 awg
a/c filler hose
brake caliper hex head set
4mm-15mm 1/4dr SK shallow socket set
6mm-15mm 1/4dr SK deep socket set
1/4-9/16 deep 1/4dr SK
3/16-9/16 shallow 1/4dr SK
10mm-18mm 3/8dr deep SK
6mm-19mm 3/8dr shallwo SK
belt tensioner tool
1/4-7/8 3/8dr shallow SK
3/8-7/8 3/8dr deep SK
than a couple of mis sockets
3/8 and 1/4 drive swivels
all are on mac magnetic trays
mac ball peen hammer set (6 ball pean hammers)
spark plug wire puller plyers mac
door pannel poper plyers mac
misc plyers 6inch 8inch
channel lock plyers mac 12inch 16inch (huge used for compressing calipers)
needle nose vice grips
regular vice grips x2
cutting dikes channel lock brand
needle nose plyers channel lock brand
c clamp 6inch
Axle nut socket set Mac 1/2dr 29mm 30mm 32mm 34mm 35mm 36mm 38mm
brake took kit (drum brakes) mac
safty glasses clear
spring compressors
blow gun mac
3/8 impact gun mac
die grinder mac
3/8 air ratchet husky
1/2 impact gun husky (500 ftlbs actualy more powerfull than the couple of mac guns ive tried)
2 tire chucks
coolant system pressure tester Mac (comes with honda adapter)
p/s pulley puller kit Mac
jack stands
oil drain
chain with bolts for breaking ball joints and lowering control arms
o2 sensor socket
spark plug sockets
tool included:
2ft pry bar Mac
42in pry bar Mac
shrink wrap
electrical tape
4 tire guages
markers
no name 3/8 ratchet
3/8 snap on ratchet
wire stripping tool
mac test light
misc fuess
diaeletric grease
contact cleaner
noname test light
a/c filler hose
belt tensioner tool
c clamp 6inch
safty glasses clear
spring compressors
blow gun mac
3/8 impact gun mac
die grinder mac
2 tire chucks
jack stands
oil drain
o2 sensor socket
spark plug sockets
goodfella732
Nov 2, 2009 11:09 AM
