Repiping brake lines with Adjustable prop valve
Old Mar 13, 2006 | 10:15 AM
Cyclonium's Avatar
Default Repiping brake lines with Adjustable prop valve
Alright lads,
I am doing this in my rex. Pic to give an idea.
I have come to the conclusion that the hardline inverted flare fittings are 10 x 1.0 mm. Is that right?
I will be running a tilton prop valve and have wilwood s/s lines up front and russell lines at the back.
i havent seen the russel lines yet but when i got the wilwodd lines with my 11" kit I recieved the following frame fitting
What is the dia of the female side of this is it 10 x 1.0 mm as it is a honda civic specific kit or would it be 3/8-24 in. ??
Where would I source some 10 x 1.0mm inverted flare fittings, i can only find 3/8-24 in. on summit racing.
Cheers
John
EDIT: These are the lines and fittings I have up front
http://store.summitracing.com/...-6419
Civic 1990-1999
HamiltonRex
Dec 19, 2010 08:10 AM
Xscort
Feb 15, 2009 11:59 AM
a1320addict
Dec 1, 2006 09:25 PM
o2flow.net
Sep 27, 2006 11:23 AM
fitnessbyday
Jul 29, 2002 08:01 AM
