A/C removing question HELP!
Old Mar 13, 2006 | 09:58 AM
IntegraMastaz's Avatar
Default A/C removing question HELP!
hi all,
I search and found nothing.
1- what to do with the tube that are going in the fire wall... wich way to remove them or just cut them ( gettho )
2- before removing compressor and misc, should I remove all the gaz from there ?
3- any hint on how to do the work the best way.
Thank you!
Old Mar 13, 2006 | 10:03 AM
Lan's Avatar
Lan
Default Re: A/C removing question HELP! (IntegraMastaz)
When you unthread the hose make sure you wear some goggles, protective clothing etc. especially some leather or neoprene chemical gloves. That **** burns; keep it away from your eyes becuase it will come out with a lot of pressure when opened..... A LOT OF PRESSURE.
Old Mar 13, 2006 | 10:34 AM
SlammedDC2teg's Avatar
Default Re: A/C removing question HELP! (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">When you unthread the hose make sure you wear some goggles, protective clothing etc. especially some leather or neoprene chemical gloves. That **** burns; keep it away from your eyes becuase it will come out with a lot of pressure when opened..... A LOT OF PRESSURE. </TD></TR></TABLE>
Dont do that. Thier is a little cap on the A/C hose next to the radiator, its like a tire cap but blue and bigger. Open that up and put a screw driver of anything in it that will press on the pin and let it go untill nothing comes out. When you remove the compressor dont remove the mount its mounted on because that is an engine mount. If you want to remove the hoses that do into the fire wall you have to get an integra RS unit for under the dash because all of the other **** like heat and air wont work because you will have a big chunk missing, i just left those in the car. I think you can remove your battery and disconnect some more hoses under it but thats where it stops.
Old Mar 13, 2006 | 11:01 AM
RaceMyGhost's Avatar
its illegal to let the pressure out just like that....u have to properly discharge the gas, and also, if you're going to discharge the gas the illegal way, make sure you cover up your distrabutor cap and wires cuz that gas will fry up your dist.cap and rotor.
Old Mar 13, 2006 | 12:01 PM
Default Re: A/C removing question HELP! (RaceMyGhost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">
its illegal to let the pressure out just like that....u have to properly discharge the gas, and also, if you're going to discharge the gas the illegal way, make sure you cover up your distrabutor cap and wires cuz that gas will fry up your dist.cap and rotor.</TD></TR></TABLE>
WOW, i didnt know that. lol
Old Mar 13, 2006 | 12:21 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: A/C removing question HELP! (SlammedDC2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2teg &raquo;</TD></TR><TR><TD CLASS="quote">WOW, i didnt know that. lol</TD></TR></TABLE>
lol.. because it's useless information.
Who is Seriously going to "discharge" the gas properly?
Old Mar 13, 2006 | 12:48 PM
ok so:
1- I remove the gaz ( the legal way of course )
2- I remove the Fan,
3- unbolt the compressor, and let say I just Cut the tube that goes on my firewall so that I can remove all that crap fom the engine bay.
will my fan heat/cold still be working or those tube are needed for some reason?
Old Mar 13, 2006 | 01:06 PM
Default Re: (IntegraMastaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraMastaz &raquo;</TD></TR><TR><TD CLASS="quote">ok so:
will my fan heat/cold still be working or those tube are needed for some reason?</TD></TR></TABLE>
remove the fan that is infront of the compressor and everything else sounds good.
b20beast83
Paint and Body
Nov 6, 2008 04:35 PM
bigislandc2
Oct 2, 2007 10:38 AM
yoffer
15
Apr 25, 2007 06:58 PM
RACEPAK
11
Mar 23, 2007 01:50 PM
escape2me
Apr 15, 2005 10:31 PM
