91 civic si keeps blowing fuse #14
Old Mar 13, 2006 | 09:58 AM
blackstar's Avatar
war all of the time......
Default 91 civic si keeps blowing fuse #14
bought a 91 civic si with d16a6 in it, kid couldnt get the motor to start. before i ever messed with the a6 i took it out and put in a z6 and converted to obd1. now here comes the problems. i'm not gettin spark or fuel. main relay does click twice, grounds all seem to be fine, so i checked all the fuses. fuse #14 keeps blowing which explains why i'm not gettin spark or fuel.
<U>helms manual says fuse #14 is for:</U>
voltage regulator
emissions control solenoid valve
PGM-FI main relay
PGM-FI ecu
fuel pump
eacv
so, i'm tryin to figure out why the fuse keeps blowing. i thought maybe there is a short somewhere but i'm not sure. i dont know what the kid had done to the car when he was tryin to get it to start with the a6 in it.
i've messed with this car for a couple days and its gettin the best of me. i figured that maybe someone else here has had this problem.
any help or input is greatly appreciated!!
THANX!!!!!!!!!!!!!!!!!!
Old Mar 13, 2006 | 10:06 AM
sohc hatch's Avatar
Default Re: 91 civic si keeps blowing fuse #14 (blackstar)
Could possibly be a short of some sort - I would try tracing all the wires that run to the fuel pump to look for shorts. I would check every single one of those components to make sure they are not faulty and check any wires going to them to make sure they don't have any shorts or stripped wires and so fourth. Good Luck.
Good Day,
RH.
Old Mar 13, 2006 | 11:21 AM
d16efsedan's Avatar
Default Re: 91 civic si keeps blowing fuse #14 (egturbohatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbohatchback &raquo;</TD></TR><TR><TD CLASS="quote">Could possibly be a short of some sort - I would try tracing all the wires that run to the fuel pump to look for shorts. I would check every single one of those components to make sure they are not faulty and check any wires going to them to make sure they don't have any shorts or stripped wires and so fourth. Good Luck.
Good Day,
RH.
</TD></TR></TABLE> what he said,definatly(sp) sounds like a short to me...
Old Mar 13, 2006 | 11:28 AM
slamedcivic's Avatar
st did the same thing nut in to a dx and i couldnt get it to start either. but i had spark and fuel . make sure ur conversion harness is right. and make sure if u re pined ur a6 dizzy to a z6 one that it is right just go off the dizzy plug.
Old Mar 13, 2006 | 02:30 PM
blackstar's Avatar
Good Day,
RH.
yea i was thinkin they might be a short in the wires to the alt, cuz this kid prob started workin on the motor and didnt disconnect the battery. i'm gonna spend a couple hours this week messin with it.
i thought surely someone else has had this problem. this is why i shouldnt buy a car that doesnt run in the first place lol
Old Mar 13, 2006 | 06:05 PM
d16efsedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamedcivic &raquo;</TD></TR><TR><TD CLASS="quote">st did the same thing nut in to a dx and i couldnt get it to start either. but i had spark and fuel . make sure ur conversion harness is right. and make sure if u re pined ur a6 dizzy to a z6 one that it is right just go off the dizzy plug. </TD></TR></TABLE> thats the best kind of car to buy its alot cheaper hehe.anyways just keep working at it you'll figure it out sooner or later like i tell everyone else,when dealing with these old of cars learn how to fix them or stay away from them
Gobiee
May 18, 2016 10:02 PM
nightkid619
Sep 11, 2007 03:15 PM
mihaelrosas
Jun 8, 2007 04:27 PM
McNizzle
Dec 10, 2004 01:31 PM
