96 Accord Axle change. Need some help
Old Mar 13, 2006 | 09:05 AM
SlammedDC2teg's Avatar
Default 96 Accord Axle change. Need some help
My moms 96 accord has a bad axle and im going to do it my self. I have done axles a million times before, but never on an AT trans. I was woundering if any one can tell me what size is the nut on the hub? Also i was woundering if i put in tranny fluid the same way as in an MT? Any help will be apreciated.
Old Mar 13, 2006 | 04:31 PM
blueshark's Avatar
Default Re: 96 Accord Axle change. Need some help (SlammedDC2teg)
The nut size is 36 mm, The method of pulling the axle out is the same as a manual trans. Just use the right size prybar for your self and pop it out.
Old Mar 13, 2006 | 05:31 PM
Default Re: 96 Accord Axle change. Need some help (blueshark)
thanks
Old Mar 13, 2006 | 06:47 PM
Honda-Master's Avatar
http://www.ozaccord.com/forums/showthread.php?t=36
go here... step by step instruction
Old Mar 13, 2006 | 06:54 PM
Default Re: 96 Accord Axle change. Need some help (Honda-Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ozaccord.com/forums/showthread.php?t=36
go here... step by step instruction</TD></TR></TABLE>
Thanks helped alot.
DopeCD5
May 15, 2016 03:30 PM
docfletcher
Feb 26, 2011 09:53 AM
01celica_gts
Aug 6, 2007 01:02 PM
delslowhonda
May 21, 2006 08:30 PM
