b18c1 block wth b16 head.. what will compression ratio be with ITR pistons
Old Mar 13, 2006 | 09:02 AM
DC2SIR-G's Avatar
* B A N N E D *
Default b18c1 block wth b16 head.. what will compression ratio be with ITR pistons
like title says.. i know it will lower comp with b16 head. but if i had US ITR pistons, wat will comp ratio be?
Old Mar 13, 2006 | 10:03 AM
sik96teg's Avatar
Default Re: b18c1 block wth b16 head.. what will compression ratio be with ITR pistons (DC2SIR-G)
This should be all you need
http://www.c-speedracing.com/h...c.php
Old Mar 13, 2006 | 10:08 AM
92TypeR's Avatar
FSAE
B16 head = ITR head
You are using UDSM ITR pistons, which are 10.6:1, and with the above information, without any milling of the head or decking of the block, your compression will be 10.6:1
Old Mar 13, 2006 | 10:11 AM
Lauj87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2SIR-G &raquo;</TD></TR><TR><TD CLASS="quote">like title says.. i know it will lower comp with b16 head. but if i had US ITR pistons, wat will comp ratio be?</TD></TR></TABLE>
I think a b16 head on a c1 block would actually make the compression shoot up...correct me if im wrong.
b16 head on b18c1 block = poor mans Type R
Old Mar 13, 2006 | 10:29 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: b18c1 block wth b16 head.. what will compression ratio be with ITR pistons (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">
b16 head on b18c1 block = poor mans Type R</TD></TR></TABLE>
youre wrong, its not a poor man R if it doesnt have the pistons the comp ratio will be lowered
EJ1_203
10
Sep 28, 2007 04:28 PM
ef8-dc2619
Feb 26, 2007 08:44 AM
Jxi8s2k
Dec 22, 2005 07:12 AM
ajchen
Nov 25, 2002 07:12 AM
SIReg9
Nov 6, 2002 10:34 AM
