JDM HONDA ACURA INTEGRA Sir-G
Old Mar 12, 2006 | 10:35 PM
jccrxtuner916's Avatar
Default JDM HONDA ACURA INTEGRA Sir-G
anybody has the pin outs for it.... im tryin got install it in my car.. is a 88 dx... with a b16 swap... pls help? ASAP thanks
Old Mar 12, 2006 | 10:46 PM
Default Re: JDM HONDA ACURA INTEGRA Sir-G (jccrxtuner916)
Old Mar 12, 2006 | 10:54 PM
SD_Lurker's Avatar
HT White Ops
Dont have a diagram but I have seen it done and I know if you search you will find something. I am sure that there are plenty of threads covering this suject. Good luck
Old Mar 12, 2006 | 10:59 PM
i knwo i tried searchign fo rit already and didnt find anythign th reason why is beasuce the jdm one does not have a brake light..
Old Mar 13, 2006 | 05:13 AM
civhatch90's Avatar
https://honda-tech.com/zero...age=1
dont know if it helps its not the same but similar
Old Mar 14, 2006 | 04:21 PM
Default Re: (civhatch90)
ok guys this is what im talkign about a JDM integra cluster the one with 3 plugs, does anybody know what each wire do? and where they would go if im to install it in a 88 crx, i already have the pin outs for the CRX, i need the ones for this cluster, pls help!!!!
cluster
back
left plug (1 through 16)
center plug (1 through 10)
right plug (1 through 13)
Old Mar 14, 2006 | 04:22 PM
cluster
back
B16CRXVTEC
18
Dec 1, 2009 09:58 PM
mrpoi808
Jun 8, 2008 01:26 PM
killacrx1
Jun 21, 2006 07:20 AM
jccrxtuner916
Mar 15, 2006 05:46 PM
Dru-Si
10
Apr 27, 2001 01:12 PM
