b16a vs b18c1 block
Old Mar 12, 2006 | 10:04 PM
tobe1424's Avatar
Default b16a vs b18c1 block
Is it true that the b16 block is 6mm shorter than the gsr block thats y compression is higher...i know stroke is different duh but like the actuall physical size of the block in height?
Old Mar 13, 2006 | 03:26 AM
NJIN BUILDR's Avatar
Default Re: b16a vs b18c1 block (tobe1424)
Yes the b16 block is shorter than the b18 blocks.Thats not why its got a higher compression ratio though.
Old Mar 13, 2006 | 06:01 AM
tobe1424's Avatar
Default Re: b16a vs b18c1 block (NJIN BUILDR)
yea i know thats not the reason why...but i know u can but a gsr stroke and crank but if you do like a stroker motor i heard there wouldn't be enought piston to valve clearance
jaredvabeach
Sep 14, 2009 01:53 PM
jowiegsr
Aug 27, 2007 07:47 PM
Option
Jan 20, 2005 11:53 PM
S10RALLYRACER
Oct 14, 2004 05:57 PM
DefiantGSR
Feb 26, 2003 05:20 PM
