Getting to the Balljoint
Old Mar 12, 2006 | 09:11 PM
vinuneuro's Avatar
Default Getting to the Balljoint
I have a 98 SH and to replace the radius rod, I need to remove the balljoint first since the radius rod has it's own balljoint. In the helms, the balljoint replacement is under the knuckle/hub replacement section so I'm not sure if some of the steps are required or not.
It says I need to remove the spindle nut. If it's removed it needs to be replaced. Do the caliper and disc even need to be removed for this? Look at pic below.
How hard is it to use a balljoint remover ,tips? How do I get the balljoint back in there? Anything else need to be done? (my first time doing suspension work). tia.
Modified by vinuneuro at 1:07 AM 3/13/2006
Old Mar 12, 2006 | 09:35 PM
vinuneuro's Avatar
Default Re: Getting to the Balljoint (vinuneuro)
Modified by vinuneuro at 1:06 AM 3/13/2006
Old Mar 13, 2006 | 05:36 AM
vinuneuro's Avatar
bizump
Old Mar 13, 2006 | 05:42 AM
The Weather Man's Avatar
I would remove the caliper and rotor just to make things easier. You might as well change your brakes while you're at it. Good luck with everything.
Oh - the high for Long Grove, IL is 54 degrees mostly cloudy. The low tonight will be around 26 degrees with some snow showers. Wind speed might get up to 35 mph, and you have a 30% chance of precipitation(rain/snow). Tomorrow is going to be cold - so enjoy 54 degrees while you can.
Old Mar 13, 2006 | 05:52 AM
vinuneuro's Avatar
Default Re: (The Weather Man)
HAHA! The Weatha Man has spoken. Thanks bud.
R-Lug
Suspension & Brakes
Dec 18, 2005 08:33 PM
haashaus
Dec 14, 2005 07:22 AM
jagged4698
Nov 18, 2004 07:04 PM
Dr Pooface
Sep 15, 2002 09:38 PM
jamal-188
Mar 5, 2002 03:53 PM
