RPM NEEDLE JUMPING
Old Mar 12, 2006 | 09:08 PM
LSVtecHatchback's Avatar
Default RPM NEEDLE JUMPING
alright here the deal..my car got stolen and i found it before they could strip it..they took my vafc which i was using to tune my motor...now im using a greddy emanage untune..but a friend of mine did some adjustment so it would run a little rich till i can tune it..but at the moment when im driving after 2k my rpm needles jumps everywere..today i was driving it and it jumped all crazy and it shutted off on me so i had to pull over.so any idea what would be wrong with it?my set up is a stock b20 turbo with 440cc injectors need more info on the car just ask
Old Mar 13, 2006 | 04:52 AM
methanemotorworks's Avatar
Default Re: RPM NEEDLE JUMPING (LSVtecHatchback)
i have the same thing happening to me...but it jumps when v-tec kicks in...im gonna run some test on it...ill let you know when i find out...also my icm signal seems to be fine because on my v-afc the rpm doesn't jump around like on the gauge...so im assuming its the gauge cluster...will keep you updated...its probably gonna be this weekend though...
Old Mar 13, 2006 | 05:08 AM
angelSIR-G's Avatar
Default Re: RPM NEEDLE JUMPING (methanemotorworks)
check the ignitor chip in your dizzy
Old Mar 13, 2006 | 05:36 AM
7mile's Avatar
could be wiring... this happened to me... check the ecu plugs... mine was doing that.. notice a wire was loose... ..
also can be the vafc
Old Mar 13, 2006 | 06:13 AM
solareclipseauto's Avatar
Default Re: RPM NEEDLE JUMPING (angelSIR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by angelSIR-G &raquo;</TD></TR><TR><TD CLASS="quote">check the ignitor chip in your dizzy</TD></TR></TABLE>
Old Mar 13, 2006 | 08:03 AM
i just changed my ignitor not to long ago but the spring thats goes into the ignitor was kinda bent so u think that might be it?and oh yea when the rpm needle jumps my mtoor jumps also
Teg6
Nov 15, 2006 05:37 AM
dblock
Oct 16, 2006 10:54 PM
LSVtecHatchback
Mar 15, 2006 02:34 PM
GOKOU
Aug 16, 2002 05:56 AM
EleanoR
Apr 17, 2002 10:29 AM
