Short Shift Kit-SEARCHED
Old Mar 12, 2006 | 08:43 PM
h22vt's Avatar
Default Short Shift Kit-SEARCHED
im pretty much a noob so sorry if this is stupid. i have a 01 prelude and im looking for a short shift kit. im having trouble finding what i want. well actually im not sure what im looking at. can anyone tell me the difference between a short shift kit and an adaptor? ive found a couple of both can anyone recommend anything? does anyone have some pics? to the people that have them, do you like them? thanks for all your help.
Old Mar 12, 2006 | 09:19 PM
h22vt's Avatar
bump
Old Mar 12, 2006 | 09:28 PM
BB6racer's Avatar
if you take the center console off your car, you will see 2 shift cables that connect to your shift arm (the metal shaft that your shift **** and shift boot cover. if you buy an adaptor short shift kit, you will recieve a little piece of metal that will relocate one of the shift cables a little higher. if you buy an actual full shift kit, you will replace the shift arm and mounting piece. the full shift kit will also relocate the shift cable. a shift kit is welded and usually very well designed and constructed, whereas an adaptor kit is bolted on and just get the job done and grind a little between shifts. if you want, you can search around on here and i've seen pics of the 2 short shifters so you can get a better idea of what i'm talking about.
edit: check this out
https://honda-tech.com/zerothread?id=1468349
Old Mar 12, 2006 | 09:30 PM
h22vt's Avatar
ok thanks, that helps a lot. i know now that im getting a full shift kit. does anyone on here have one? and if so what kind?
Old Mar 12, 2006 | 09:37 PM
joeboxer212's Avatar
I'm getting my pspec. Everyone that I've talked to loves theirs. 1" lower, 40% reduced throws...and stock smoothness =]
Old Mar 12, 2006 | 10:06 PM
hu's Avatar
hu
Get a 4bidden short shifter.
Old Mar 12, 2006 | 11:14 PM
soundbomber's Avatar
Default Re: (hu)
he hasn't made one for 5th gen yet
FadeToBlack's Avatar
Don't believe there is a 4bidden for 5th gens...poor guys.
^beat me by 4 seconds
Old Mar 12, 2006 | 11:33 PM
hu's Avatar
hu
^ Sorry for the bad info...
What about a Lean Racing SS?
Modified by hu at 3:44 AM 3/13/2006
Old Mar 13, 2006 | 07:05 AM
98vtec's Avatar
moderator emeritus
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">^ Sorry for the bad info...
Modified by hu at 3:44 AM 3/13/2006</TD></TR></TABLE>
havent heard from him in atleast 8 months. I was supposed to be testing his new shifter, but he dropped off the face of the earth once again.
Old Mar 13, 2006 | 11:21 AM
E-Money's Avatar
Default Re: Short Shift Kit-SEARCHED (h22vt)
pspec shifter for a 5th gen
http://www.pspectuning.com/9701prelude.php
MatthewMenze
Transmission & Drivetrain
Feb 22, 2013 09:51 PM
732xghost
Jan 10, 2007 07:11 AM
FinalAeon
Jun 4, 2005 07:17 PM
GQ 05YellowEVO8
Aug 14, 2004 10:31 PM
M0NEYnH0s
Feb 4, 2002 07:04 AM
