Fuel pressure regulator
I installed a fuel pressure regulator on my gsr today, nothing done right now just i/e. The gauge is reading 52 psi, is that good enough for a stock gsr? However, this next two weeks I will be adding ctr cams, skunk2 intake manifold, and a jdm itr header and tune it on my vafc. So thats my other question, after it is tuned what is a safe psi to run on the regulator?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one »</TD></TR><TR><TD CLASS="quote">are you talking about at WOT or at idel... with or without the vaccum hose connected?</TD></TR></TABLE>
at idle it is about 50-52 vaccum connected. i want to know what it should be at now vaccum connected and with the mods. and should i not have the vaccum on?
Guest
Posts: n/a
with the basic mods you have i would keep it around stock, no higher than 42 i say this because i once thought the higher the fuel pressure the faster it is... but in reality your injectors can only handle so much and if you turn it up too high its just going to flood keep it stock unless your throw on a turbo or go built internaly n/a
TakaIntegra
Jun 17, 2002 09:55 PM
