take off an oil filter
Old Mar 12, 2006 | 08:20 PM
ahloung's Avatar
Default take off an oil filter
how do you take off the oil filter in a del sol? its not straight down... its going sideways and theres things in the way... i can reach it but its to tight on to take off with my hand but my filter wrench cant reach it.. how can i take it off?
Old Mar 12, 2006 | 08:24 PM
pro1342's Avatar
There are oil filter pliers available, and also cups that fit on the end of the filter (kind of like an oil filter socket). If you dont have access to those, the oil filter wrench is your best bet.
Old Mar 12, 2006 | 08:27 PM
zacatkings's Avatar
Default Re: (pro1342)
reach up and grab it like every other honda person does
Old Mar 12, 2006 | 08:30 PM
pro1342's Avatar
Default Re: (zacatkings)
Old Mar 12, 2006 | 09:38 PM
killerformula's Avatar
Some of those filters (especially the honda brand ones) are so small in diameter that most wrenches wont even fit on it. If you're having serious problems get the car up on some jack stands and get a screwdriver. Get a hammer and tap the screwdriver through the very end of the filter till it comes out the other side. grab either end of the sucker and twist that bastard off.... no personal experience here... lol
K
Old Mar 12, 2006 | 09:39 PM
ahloung's Avatar
where on the car would i put the jack stands? i usualyl dont use them
Old Mar 12, 2006 | 09:49 PM
cxtengoku's Avatar
Default Re: take off an oil filter (ahloung)
lol. u should use jack stands if u value ur life. but there should b 2 jacking points near the back of the front fenders. u can put the jack stands on those while ur lifting the car in the front.
SOHC4life 96's Avatar
Default Re: (ahloung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">where on the car would i put the jack stands? i usualyl dont use them</TD></TR></TABLE>
I hope you aren't working under your car while it's chillin' on the jack then... A friend of mine had a car fall of a jack, bounce of his chest, go into the house, sit down on the couch tell his mom he thinks he's going to die and then dropped dead in front of her.
Anyways, they go on the jack points on either side of the car right behind the front fender on the bottom. Look on the bottom of the car right behind the front tires and look for a tab that is about 2-3 inches long. That's where they go.
Old Mar 12, 2006 | 09:54 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">I hope you aren't working under your car while it's chillin' on the jack then... A friend of mine had a car fall of a jack, bounce of his chest, go into the house, sit down on the couch tell his mom he thinks he's going to die and then dropped dead in front of her.
Anyways, they go on the jack points on either side of the car right behind the front fender on the bottom. Look on the bottom of the car right behind the front tires and look for a tab that is about 2-3 inches long. That's where they go.</TD></TR></TABLE>
yeah that happened a few times around here...
good discription too
To the original poster: I think you should watch someone change your oil before you try to do it yourself, and end up killin yourself in your driveway using a honda jack 3 hammers 4 u buddy
Old Mar 12, 2006 | 09:56 PM
ahloung's Avatar
anyone have a pic of where the jack stands go?
Old Mar 12, 2006 | 10:09 PM
cxtengoku's Avatar
Old Mar 12, 2006 | 10:10 PM
ahloung's Avatar
thx
Old Mar 12, 2006 | 10:16 PM
strictly.business's Avatar
Banned
i just replaced my clutch. i had my my jackstands on the plates that youd use for towing. it was actually really sturdy, it just looked scary. by the way, go somewhere and have your oil changed if youre not going to be under the car for another reason. same goes for me, i ******* regret doing my clutch myself. what a waste of a day and energy.
Old Mar 12, 2006 | 10:19 PM
ahloung's Avatar
yea i was thinking about puttin it on the towing plates... it looks unsturdy tho
Old Mar 12, 2006 | 10:22 PM
EJ8VTEC's Avatar
Mr. Indecisive
put the jackstands where they are supposed to go...
i kno it sucks, but im tryin
Old Mar 12, 2006 | 10:24 PM
ahloung's Avatar
what happens if i change my oil but dont replace the oil filter?
Old Mar 12, 2006 | 10:27 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">what happens if i change my oil but dont replace the oil filter?</TD></TR></TABLE>
common sence will tell u that it wont filter right...
what happends when you use a water filter when its too dirty??
I really dont think you should be working on your car.. turn off ur car as soon as you see your oil light go on lol
Old Mar 12, 2006 | 10:36 PM
EGwhat!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">anyone have a pic of where the jack stands go?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">what happens if i change my oil but dont replace the oil filter?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">where on the car would i put the jack stands? i usualyl dont use them</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahloung &raquo;</TD></TR><TR><TD CLASS="quote">how do you take off the oil filter in a del sol? its not straight down... its going sideways and theres things in the way... i can reach it but its to tight on to take off with my hand but my filter wrench cant reach it.. how can i take it off?</TD></TR></TABLE>
if you have to ask these kind of questions then you really shouldnt be changing the oil your self.. save your self some time and take it some where to get the oil changed its only 20 bucks
Old Mar 12, 2006 | 11:07 PM
ahloung's Avatar
you have to start learning from somewhere rite?
Old Mar 12, 2006 | 11:15 PM
Cuda70's Avatar
Default Re: take off an oil filter (92civichatchgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatchgsr &raquo;</TD></TR><TR><TD CLASS="quote">if you have to ask these kind of questions then you really shouldnt be changing the oil your self.. save your self some time and take it some where to get the oil changed its only 20 bucks</TD></TR></TABLE>
Actually, I applaud anyone that wants to learn to work on their own vehicles.
You have to start somewhere, so starting with the easiest of tasks is a good place.
I remember the first thing I ever did to a car. I had a starter go out in my 2 year old 1972 Chevy Nova. I called around and was given quotes that I could not afford as a young teenager paying on a car note. I called a parts store and the thing was like $25.00! So I said, "Hey, how hard could this be to do myself?" So I pushed my car up on ramps and put a new starter in my car.
The fun never ended from there on out.
OP: Just remember friend, the most important thing to working on a car is being safe. Dont take chances with your health. Anything else can be replaced, rewelded, reworked, or retooled.
And one last thing... if you have parts left over after you are done with something, it is time to worry. Although, I have honestly said, "Hmmm, that must not be too important, the thing runs..."
Old Mar 13, 2006 | 04:33 AM
DannyDeuce's Avatar
I just use an oil filter cap (see pic). It just fits over the oil filter then you stick the ratchet in the square opening and screw it off. Very easy.
Side note: I use ramps, be careful if you have a lowered car though
DAN
Old Mar 13, 2006 | 05:19 AM
AutoXer's Avatar
Default Re: take off an oil filter (DannyDeuce)
To the OP:
Go out and pick up a Haynes manual from the parts store. It's not as good as a Helms (factory service manual) but it can answer some of these basic questions you have pretty well. I'd also try to find someone who knows what they're doing to help you out if possible. If you don't have either of these things, I would take it to a shop. You don't want to damage the car or yourself.
Old Mar 13, 2006 | 05:38 AM
Russ713's Avatar
dAng!
I've done it two ways on my old one. Either remove the intake pipe and reach down, or raise the car up and go from underneath.
Old Mar 13, 2006 | 07:31 AM
ahloung's Avatar
Default Re: take off an oil filter (Cuda70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuda70 &raquo;</TD></TR><TR><TD CLASS="quote">
And one last thing... if you have parts left over after you are done with something, it is time to worry. Although, I have honestly said, "Hmmm, that must not be too important, the thing runs..."</TD></TR></TABLE>
thanks
suspendedHatch's Avatar
Default Re: take off an oil filter (Russ713)
Big pair of channel locks.
If you're poking holes in the filter then you're just not being very creative.
I had a car fall on my head last year. Double vision for 6 months.
