aluminum downpipe and dumptube
Old Mar 12, 2006 | 07:23 PM
redboost10's Avatar
Default aluminum downpipe and dumptube
i was planning on going with a ss 4" downpipe and a ss 2" dumptube. but i was thinking that is going to be pretty heavy. is anyone using aluminum downpipes and dumptubes, not too much worried about the dumptube. whats the thickness of the aluminum to go with when using it as a downpipe? thank you.
Old Mar 12, 2006 | 07:44 PM
rkeith's Avatar
Default Re: aluminum downpipe and dumptube (tgh99si)
Aluminum isn't a good choice for exhaust components on a street car. Aluminum will fatigue easily. Also, the weight savings will be minimal.
Old Mar 12, 2006 | 07:51 PM
redboost10's Avatar
Default Re: aluminum downpipe and dumptube (rkeith)
well it isnt really a street car. i thought ive read that if its thick enough, it wont fatigue. so 4" ss vs. 4" al downpipe... would everyone go with the 4"ss?
Old Mar 12, 2006 | 08:50 PM
redboost10's Avatar
anyone else have any information or is anyone running an aluminum downpipe
Old Mar 12, 2006 | 10:07 PM
Ekasey's Avatar
the weight savings would be pretty significant
4" X .065 304ss weighs 2.73 lbs/ft
4" X .065 6061 weighs .095 lbs / ft
I would recommend a stainless steel downpipe and dump tube.
If you are going to run the exhuats towars the rear of the car I would use alu from say where the tunnel starts.
If you bracket the exhaust correctly you should not have issues with the aluminum fatigueing just be sure not to stress the part.
Old Mar 12, 2006 | 11:28 PM
redboost10's Avatar
Default Re: aluminum downpipe and dumptube (Ekasey)
so is there a thickness of aluminum pipe that you recommend for exhaust pipe. that weight is pretty light. so aluminum downpipe is pretty much not a good idea? thank you for the information ekasey.
Old Mar 13, 2006 | 03:39 AM
rkeith's Avatar
Keep in mind he wants to run thicker AL tubing to compensate for the stress so comparing the weight between the same wall tubing doesn't work.
Old Mar 13, 2006 | 05:17 AM
dfoxengr's Avatar
the dumptube would probably melt.
Old Mar 13, 2006 | 06:44 AM
ccivic's Avatar
Default Re: aluminum downpipe and dumptube (dfoxengr)
Just another excuse for losing a race:
"Dude!! My dump tube melted again.. not fair!"
Old Mar 13, 2006 | 07:36 AM
Ekasey's Avatar
Regardless of material thickness I would not use it for the downpipe only for an exhaust after the downpipe.
If you want to save some weight on the dump tube we do have some 2" X .035 321ss that should work just fine
Old Mar 13, 2006 | 07:54 AM
redboost10's Avatar
ok, thank you everyone. i just thought i saw someones setup and they were using an aluminum downpipe, but i didnt know for sure. and im assuming that .035" ss is too thin for downpipe material?
Old Mar 13, 2006 | 08:01 AM
Ekasey's Avatar
Yeah it's a little thinner then I would feel comfotable going, on top of that it is extremely hard for us to source 4" 321 .035
Old Mar 13, 2006 | 12:04 PM
redboost10's Avatar
for a track only car, a 4" ss downpipe is all that is really needed. you dont really need a full exhaust all the way to the back.
Old Mar 13, 2006 | 01:32 PM
dfoxengr's Avatar
those 3 lbs of weight are really going to help out too.
shave it off your stomach before going with some thin tube...
Old Mar 13, 2006 | 01:35 PM
Ekasey's Avatar
If it's only a DP stick with the stainless
Old Mar 13, 2006 | 03:30 PM
.RTErnie's Avatar
I dunno man he's pretty skinny as it is. lol Shaving off personal weight isn't a good idea.
Hit me up travis, I'll tig that up for you.
-Urness
Old Mar 13, 2006 | 05:53 PM
redboost10's Avatar
Default Re: aluminum downpipe and dumptube (~RTErnie~)
thanks urness, im thinking about just going with a 4" downpipe, no exhaust, how loud can it be...who cares, its pretty much a track car only.
yeah i dont think i have any weight to lose at the time.
Old Mar 17, 2006 | 08:45 AM
supercreed2002's Avatar
let think about this....hot gas from turbo right? first bend in aluminum will subject all those hot gas on that one spot(outter bend) and may do damage.
JBLAZE622
Apr 29, 2010 04:30 PM
Jared
Welding / Fabrication
Oct 24, 2007 07:27 PM
eastbay92cx
Oct 13, 2004 06:20 PM
shermanyang
Sep 13, 2002 07:17 PM
