Motul Brake Fluid....(is the search function working?)
(First need to apologize if this has been answered before, but I cannot find the answer in the search)
I will be bleeding my brakes soon, where I can get Motul Brake Fluid? What is a good price for the fluid? Thanks in advance.
Do we need to change the brake lines for the motul 600? I am not well informed on this subject, can someone please clearify if the motul 600 is compatible for our brake systems or if we need to modify anything. thanks
my search brought this thread up
https://honda-tech.com/zerothread?id=91191
kinda related but not also
https://honda-tech.com/zerothread?id=91191 kinda related but not also
You do not need to change brake lines for Motul RBF 600. It's a DOT 4 fluid (meets DOT 5 boiling points) and can be mixed with any other DOT 3 or DOT 4 or DOT 5.1 fluid.
Mike, I thought you only need two bottles for a full flush on the ITR... no?
dave, me and the local boys (ralph, lance, matt, jeff) are ordering 2 cases of ate superblue (1 blue, 1 yellow). let know if you want in for 2 cans ($9/can). 1 can will completely flush the brake system with some leftover.
Here are the dry and wet boiling points for many of the most popular brake fluids:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
You'll note that the boiling point of Motul RBF 600 is 57 degrees higher than ATE. That's a big difference.
Motul RBF 600 =
Motul RBF 600 =
Cory man
43
Apr 23, 2006 10:44 AM
