Obd 1 vtec solenoid work on obd0 motor?
Like it says, using an 94 gsr solenoid on a jdm obd0 b16. Will it work? Obviously you can't get the jdm obd0 vtec solenoid from the dealership, so need some options
adding to the question: the same part is applicable to all 92-01 teg's so....if this helps any..?
http://www.acuraoemparts.com/d...=Part
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">How many sensors does it have ? </TD></TR></TABLE>
What do you mean?
What do you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">The newer cars only have a vtec solenoid sensor, the older cars have an oil sensor on the vtec solenoid.</TD></TR></TABLE>
so if they do differ, does that state that they are not interchangeable?
yes..ive had an obd0 and obd1 b16 and now i have an obd1 gsr..they are all the same..the vtec solenoid might have a different plug on it..greay compared to creme..but its only a single wire connecter and can easily be spliced or repinned with the right connector
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d »</TD></TR><TR><TD CLASS="quote">
so if they do differ, does that state that they are not interchangeable?</TD></TR></TABLE>
There interchangeable but it the ecu is looking for 2 sensors and you only have 1, you will have a check engine light
sorry if im wrong..but from my understanding they are both the same..
an oil pressure switch and the vtec solenoid.
i have an obd0 solenoid im using as a paperweight right now..
94 gsr one in my engine bay
and i believe my girls 99 gsr is the same too..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi »</TD></TR><TR><TD CLASS="quote">sorry if im wrong..but from my understanding they are both the same..
an oil pressure switch and the vtec solenoid.</TD></TR></TABLE>
You are wrong, on all vtec solenoids there is the vtec switch but only some have a vtec oil pressure sensor on them.
x4thGenCafe
25
Jan 5, 2008 09:00 PM
