has anyone experienced the same weird speed reading?
Old Mar 12, 2006 | 03:41 PM
98RS-R's Avatar
Default has anyone experienced the same weird speed reading?
today I drive my teg on hwy 404 from Newmarket to Toronto....I was driving like around 140km/hr all the way until I noticed there's something wrong on the speed meter......the needle drop from 140km/hr to 80km/hr suddenly and back to 140km/hr in 1 sec....and the needle keep moving up and down unstably. The car didn't slowdown or speedup at that time....it just run well in constant speed........
After i slow down the car to around 100 km/hr, the speed meter then back to normal
i took the video from my cell phone see if anyone has any idea...?
click on the link to see it ---> mov00002.3gp
P.S. I've change the GSR cluster
Old Mar 12, 2006 | 03:52 PM
2SlowDC's Avatar
ure vehicle speed sensor may need to be replaced. happend to me simply from unplugging it. found out one of the pins on the vss was slightly cracked(corroded) which caused fluctuating in the speedometer. I simply soldered the pin for a easy fix
Old Mar 13, 2006 | 08:49 PM
98RS-R's Avatar
Default Re: (No-Tec)
actually where's the VSS located? is it simply unplug the wire behind the cluster and check if anything wrong and plug back in?
thanks
Old Mar 13, 2006 | 10:56 PM
2SlowDC's Avatar
the vss is on top back of the tranny behind the starter. held down by (1)10 mm
Old Mar 14, 2006 | 02:59 AM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No-Tec &raquo;</TD></TR><TR><TD CLASS="quote">the vss is on top back of the tranny behind the starter. held down by (1)10 mm</TD></TR></TABLE>
Held on by 2 10mm. Other then that, nice writeup.
Old Mar 14, 2006 | 06:43 AM
solareclipseauto's Avatar
Default Re: (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No-Tec &raquo;</TD></TR><TR><TD CLASS="quote">ure vehicle speed sensor may need to be replaced. happend to me simply from unplugging it. found out one of the pins on the vss was slightly cracked(corroded) which caused fluctuating in the speedometer. I simply soldered the pin for a easy fix</TD></TR></TABLE>
Old Mar 14, 2006 | 07:46 AM
Micha's Avatar
FAILWGN
Default Re: (solareclipseauto)
No-tec... Good job increasing your thread count. Did you have anything to add?
Old Mar 14, 2006 | 09:44 AM
ScubaStevesVtec's Avatar
that same thing happened in my friends 98 civic hatchback. It was the speed sensor, but it could also be your wiring.
Old Mar 15, 2006 | 12:23 AM
2SlowDC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">
Held on by 2 10mm. Other then that, nice writeup. </TD></TR></TABLE>
its 1. the two 10 mm bolts ure talking about are holding the actual vss on a bracket which is held down on the tranny with 1 10 mm bolt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote">No-tec... Good job increasing your thread count. Did you have anything to add? </TD></TR></TABLE>
Yes I do. F you. Im providing this guy(and many others who have the same problem) a definitive answer from first hand experience. If I gave a **** about my thread count Id be posting useless/wrong info like you.
Chee_dog
Nov 17, 2006 07:39 PM
b_serious
Acura TSX
Dec 7, 2005 08:42 AM
ryan12321
Jan 16, 2003 08:54 AM
