Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
- How to Program Garage Door Opener
Step by step instructions for do-it-yourself repairs
How to program a garage door opener
I have a 00 accord 4dr and was wonderning how to program the garage door opener to my car?? i dont have the manuel so thats why im asking here
thanks guys
thanks guys
Assuming your referring to the homelink system in your sunglasses holder:
http://www.homelink.jci.com is your customer assistance website.
Before you begin - If you just took
delivery of your vehicle and have
not trained any of the buttons in the
HomeLink transmitter before, you
should erase any previously learned
codes before training the first
button. To do this, press and hold
the two outside buttons on the
HomeLink transmitter until the red
light flashes. Release the buttons,
then proceed to Step 1.
If you are training the second or
third buttons, go directly to Step 1.
1. Unplug the garage door opener
motor from the house current.
2. Hold the end of the garage door
opener remote control 1 to 3
inches from the HomeLink
transmitter. Make sure you are
not blocking your view of the
red light in the transmitter.
3. Select the transmitter button
you want to train.
4. Press the button on the remote
control and the button on the
transmitter at the same time.
Hold down both buttons.
Canadian Owners: The remote
control you are training from
may stop transmitting after two
seconds. This is not long
enough for the HomeLink
transmitter to learn the code.
Release and press the button on
the remote control every two
seconds until the transmitter has
learned the code.
5. The red light in the transmitter
should begin flashing. It will
flash slowly at first, then
rapidly.
6. When the red light flashes
rapidly, release both buttons.
The transmitter should have
learned the code from the
remote control.
7. Plug in the garage door opener
motor, then test the transmitter
button by pushing it. It should
operate the garage door.
If the button does not work,
repeat this procedure to train it
again. If it still does not work,
you may have a variable orrolling code garage door
opener. Test this by pressing
and holding the HomeLink
transmitter button you just
trained. If the red light blinks
for two seconds, then stays on,
you have a rolling code garage
door opener. You may be able
to verify this with the
manufacturer's documentation.
Go to "Training With a Rolling
Code System."
8. Repeat these steps to train the
other two transmitter buttons to
operate any other remotelycontrolled
devices around your
home (lighting, automatic gate,
security system, etc.).
Training With a Rolling Code
System
For security purposes, newer
garage door opening systems use a
"rolling" or variable code.
Information from the remote
control and the garage door opener
are needed before the HomeLink
transmitter can operate the garage
door opener. The "Training the
Transmitter" procedure trains the
HomeLink transmitter to the proper
garage door opener code. The
following procedure synchronizes
the HomeLink transmitter to the
garage door opener so they send
and receive the correct codes.
It may be helpful to have someone
assist you with this procedure.
1. Make sure you have properly
completed the "Training the
Transmitter" procedure.
2. Find the "Training" button on
your garage door opener unit.
The location will vary,
depending on the manufacturer.
The manufacturer's
documentation may help.
3. Press the Training button on the
garage door opener unit until
the light next to the button
comes on, then release it. The
light may blink, or come on and
stay on. You then have
approximately 30 seconds to
complete the following steps.4. Press and release the button on
the HomeLink transmitter. (The
same button you trained with
the "Training the Transmitter"
procedure.)
5. Press and release the
HomeLink transmitter button
again. This should turn off the
training light on the garage
door opener unit. (Some
systems may require you to
press and release the button up
to three times.)
6. Press the transmitter button
again. It should operate the
garage door.
Retraining a Button
To train an already programmed
transmitter button to operate a new
device:
1. Select the transmitter button
you want to train.
2. Press and hold the transmitter
button until the red light begins
to flash slowly (approximately
20 seconds).
3. While continuing to hold the
transmitter button, place the
remote control for the device 1
to 3 inches from the HomeLink
transmitter.
4. Press and hold the button on the
remote control. Hold both
buttons until the red light
begins to flash rapidly.
5. Release both buttons. The
transmitter should now be
trained to operate the device.
Erasing Codes
To erase the codes stored in all
three buttons, press and hold the
two outside buttons until the red
light begins to flash, then release
the buttons.
You should erase all three codes
before selling the vehicle.
you want to train.
learned the code.
rapidly.
remote control.
Code System."
devices around your
System
The manufacturer's
procedure.)
to three times.)
garage door.
Retraining a Button
device:
you want to train.
20 seconds).
transmitter.
Erasing Codes
the buttons.
bochin
Dec 10, 2011 05:27 AM
Dekka
Nov 18, 2002 10:08 PM
