b16a in crx dx
ok i have a 91 crx dx with the d15b2 in it with dpfi and i wam going to buy the sir1 motor from hmotorsonline.com wat all would i have to do to get it in can some one give me a site that has the hole instal or some thing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">answers</TD></TR></TABLE>
best site ever right there
convert to mpfi, contact rywire.com or
b16a
y1 tranny with sir axles and pw0 ecu, contact raxles or hasport
s1, or j1 tranny with 90-93 axles and pr3 ecu, contact raxles, hasport, or local parts store
might need half shaft: 90-93 integra with 90-93 axles
vtec subharness, make yourself or contact rywire.com or hasport
b-series mounts, contact hasport, http://explicitspeedperformance.net or other mount maker
custom shift linkage, contact hasport
90 integra energy shift linkage bushings, jegs or anywhere
Upper radiator hose 92 GSR, trim to fit
Lower radiator hose 90 Integra, trim to fit
integra 90-93 throttle cable or custom bracket
if you get your motor from hmo they will be able to get you hasport products. above will get your engine in. below is stuff you should get.
full tune up (plugs, wires, dist. cap & rotor, etc...)
timing belt w/ tensioner
all belts
water pump
cam seals
oil pan gasket
spark plug grometts
clutch & flywheel
and anything else you dont want to replace with the engine in your car.
i didnt and wont give you all the info needed, you'll need to find it. its readly available. ask part suppliers, search thier websites. search google. there is about 5 different write ups available online you can find. here is some:
http://www.norcalcrx.org/dropp...p.htm
http://www.hasport.com/Tech/Installs/ Shopping%20Lists/M88-B16%20partslist.htm
http://www.geocities.com/teampimports/b16a.html
http://www.crxresource.org/mod...d=134
http://forum.crxclubholland.nl...36668
http://b16a.honda-perf.org/theswap.html
http://www.norcalcrx.org/droppedcrxsi/B16a.htm
those links should be more than enough to get you started.
b16a
all belts
water pump
cam seals
oil pan gasket
spark plug grometts
clutch & flywheel
