How to drive with LSD?
Old Mar 12, 2006 | 01:37 PM
blub18's Avatar
Default How to drive with LSD?
Got a 92 civic dx hatch with a gs-r motor and a brand new type-r transmission. I live in the dallas texas area and thursday theres some pretty cool street races that i go to. So the deal is i had stock 13" rims crappy tires so when i lanch i hardly feel the lsd working, also i lanch it now beacuse i got 800 miles on it. Last thursday i put 15" si wheels with the azenis 615's (i work at discount tire). I get to the street races and lanch at 3-4000.. NOTHING BUT WHEEL HOPE so i hear wheel hope is bad because you can break your axles so i stop. try 2500rpm lanch and boooog. SO MY QUESTION IS HOW DO PEOPLE WITH ITR'S LANCH OR ANYONE WITH LSD??
ps: i got a act heavy duty clutch with a stock ls flywheel , i know i know.. im trying to get a type-r flywheel from someone.
Old Mar 12, 2006 | 01:40 PM
lemon_juice's Avatar
Default Re: How to drive with LSD? (blub18)
its not the lsd causing you the wheel hop, actualli my wheel hop from my jdm D15B tranny helped my wheel hop over my DX tranny.
tallyturbo's Avatar
first if i were you i would only change my rpm's a few hundreds at a time. you jumped from 4000 to 2800. there has to be a happy medium in there somewhere
Old Mar 12, 2006 | 01:42 PM
StreetEG's Avatar
Default Re: How to drive with LSD? (tallyturbo)
get stiff *** motor mounts
pdiggitydogg's Avatar
dont street race...its retarded
Old Mar 12, 2006 | 01:44 PM
bluemax189's Avatar
Default Re: (pdiggitydogg)
^agreed.
Old Mar 12, 2006 | 01:49 PM
madlion's Avatar
Default Re: (bluemax189)
i got a quiafe and i still get wheel hop. i stiffened the front struts and that helped.. traction bars and drag springs also help.. better motor mounts.. but youll sacrifice comfort for launching.. perhaps if you just get some traction bars youll be good.. the stiff motor mounts or motor mount inserts can cause extreme vibrations
Old Mar 12, 2006 | 01:54 PM
Soccerking3000's Avatar
Default Re: (madlion)
wheel hop is caused by the lower control arm flexing then springing back, the only realy way to get rid of it is to get traction bars. New motor mounts and springs will only have a slight affect on wheel hop so its not even worth it.
Old Mar 12, 2006 | 03:07 PM
WangChung's Avatar
Default Re: (Soccerking3000)
concentrate more on clutch release than what rpm youre launching at, to get rid of wheelhop. smoother clutch release will result in less wheelhop, where as popping the clutch at 4000rpm will cause wheel hop due to possibly worn bushings(motor mount, lca, etc). i had this problem, then got es poly mount inserts and i have zero hop, even with my beastly 111hp
Old Mar 12, 2006 | 03:13 PM
Karizmah's Avatar
Lol dont street race it's bad for your health. There is really no need to "launch"
With the low gear ratio of that tranny you should just hammer on the gas not
dump the clutch. You are doing more harm to your engine than you think.
Old Mar 12, 2006 | 03:35 PM
blub18's Avatar
Default Re: How to drive with LSD? (Karizmah)
i dont race unless i drive around the area and notice its safe, also as much as it sounds like i street race for the hell it i dont if you were here you would see its a safe place. Where and what kind of traction bars are good out there.. sometimes when i lanch at 3 my tach and dashboard shake violently.
Ps: anyone selling a 92-95 civic ex gauge cluster?
Old Mar 12, 2006 | 03:56 PM
Targa250R's Avatar
be professional
Stop street racing, ******* - then you won't have to worry about it.
Old Mar 12, 2006 | 04:38 PM
SD1222's Avatar
Default Re: How to drive with LSD? (Targa250R)
then he'll be asking the same question again when he races at the track. So what's your point?
Old Mar 12, 2006 | 04:59 PM
fraknstien's Avatar
Default Re: How to drive with LSD? (jdm_spoonEG)
you should try feeling the lsd on the turns.. hoe yea hahhah esp track =]
Old Mar 12, 2006 | 05:00 PM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">dont street race...its retarded</TD></TR></TABLE>
Also, on a totally separate note, what's with the gramatical skills of the people posting from Texas lately?!??!??!??! This is the 4th or 5th thread that I have read lately that I could barely understand.
jdmsleeper12
Transmission & Drivetrain
13
Jan 21, 2010 04:58 PM
C5teg
Dec 21, 2007 01:17 AM
s0flyy56
May 23, 2007 06:36 PM
Toy Civic
Apr 7, 2007 06:19 AM
Soku1kcivic
Apr 16, 2002 04:21 PM
