Q: 1/2 drive, Metric, Deep, 6 pt, Impact Sockets:
Old Mar 12, 2006 | 12:48 PM
diyer's Avatar
* B A N N E D *
Default Q: 1/2 drive, Metric, Deep, 6 pt, Impact Sockets:
Anyone got an opinion based on personal experience with most of the major brands as to which brand you prefer and why? The reason I ask is that I found an old file I copied from the Internet years ago that stated (guy was a welder and used these tools quite a bit, and he was always honest with me):
" ... Impact sockets are the sockets I use most. I use mostly Harbor Freight!! Yep, the cheapest ones around! But, they are also the very best at holding up. I have killed Snap-on, Mac, Allen, and many others in half the time that a H-F one lasts. BTW, Sears gets their impact sockets from Ingersoll-Rand and I-R buys them from H-F just like all their air tools. Same deal on these. So, the next time you're at sears, look at the air body saws that were selling for about $159.00. This same saw can be had from I-R for $189.00 and from H-F for about $50. Same saw inside just some minor outer case changes and a major price difference."
Hmmm, I called Sears and they said Danaher Makes their impact sockets. I'm skeptical. Perhaps Sears changed vendors.
Of the brands I was considering, they are as follows: Sears are the lowest price (on sale now), but most of the prices I was quoted are all within $10 of each other, otherwise.
Craftsman Impacts --- Mfg by Danaher for Sears, three forgings not dedicated
Williams Impacts --- One forging not dedicated
SK --- One forging not dedicated
Armstrong --- Mfg by Danaher for Sears, three forgings not dedicated
What I mean by dedicated forging is that each bar stock of steel is of its own diameter, so that all the sockets made are proportional. When a single bar stock is used for more than one socket size, the result is that the smaller of the two sizes has a wall thickness of approximately 2 mm too much. When they are proportional the difference in wall thickness is approximately 1 mm, either smaller or larger. I find proportional sockets more desirable. I dislike seeing the unnecessary fatter walls.
The other question I have is about the sizes I was advised to get, which are:
12 thru 19 mm, and then 21, 22, 24, 27, 30, 32, 34, 36 mm. I have personally used 12 thru 19, 21, 22, 24, and 36 mm, but nothing else. I wonder what some of those sizes are for?
I was told not to buy: 10 and 11 mm, stating that a 1/2 impact with break the bolt easily. Skip 20, 23, 25, 26, 28, 29, mm as they are rarely used if ever.
Opinions please?
Old Mar 12, 2006 | 01:34 PM
P_Adams's Avatar
Default Re: Q: 1/2 drive, Metric, Deep, 6 pt, Impact Sockets: (diyer)
I go for the most convient and the best warranty (with restrictions).
Snap-on was great as far as a warranty went (even replaced a box wrench I had bent for an alignment tool), but you had to wait a week to replace it. Mac tools was much the same.
I use Craftsman. They're convient (just down the street (in three directions) and don't question anything.
I will not use an impact on the smaller sizes ( I prefer not breaking things)
For 13mm to (say) 19mm, I'll use a 3/8 Impact gun or an Air Ratchet.
The larger one's see the 1/2 (and larger) Guns. (on the way off)
I'm a firm believer in torque wrenches.
P
turbojeesx
Welding / Fabrication
Dec 10, 2008 04:02 PM
HT Chaplain
11
Nov 23, 2008 03:48 AM
JDubya
14
Jun 5, 2008 08:21 AM
MaddMatt
38
Feb 26, 2005 08:15 AM
