Questions about Innovative front crossmember...
Old Mar 12, 2006 | 10:05 AM
crooked muffler's Avatar
Default Questions about Innovative front crossmember...
How much is the actual weight difference from the stock front x member?
Ive heard its lighter but have never seen actual numbers; also how much heavier is the one with the front mount?
and if one uses the stock radiator, do they have to put something underneath it to compensate for the added room?
Old Mar 12, 2006 | 03:39 PM
Default Re: Questions about Innovative front crossmember... (cheap4dr)
c'mon someone must be able to give me detailed info.
Old Mar 13, 2006 | 09:35 AM
ttt
Old Mar 13, 2006 | 12:12 PM
no one knows?
Old Mar 16, 2007 | 08:10 PM
Default Re: Questions about Innovative front crossmember... (crooked muffler)
i still want to know
Old Mar 16, 2007 | 08:27 PM
boosted crx-r's Avatar
I have one but do not know the exact difference in weight. I bought it to gain clearance for my turbo setup which was more then enough! The round tubing that it was made from did not seem strong enough for me so I cut it out and welded in a section of square tubing. If you get one I would STRONGLY suggest welding in a section of square tube!!!!
Old Mar 17, 2008 | 06:56 AM
hamst3r3x's Avatar
Default Re: Questions about Innovative front crossmember... (boosted crx-r)
boosted crx can you post up pics of what you did
9000rpms
Jul 19, 2006 03:34 PM
VTECAcuraGSR
13
May 17, 2005 12:05 PM
servion
Welding / Fabrication
Feb 21, 2005 09:31 AM
chasrex
May 16, 2002 01:53 PM
