1990 prelude need help
It's a good engine as long as the FRM lining isn't all chewed to ****. If that's the case, your rings are going to go and you will burn oil quite a bit. If you regularly have to add oil to your car, then you arre there already.
Short answer, no you can't put the b18 head on it.
Technically, sure. But you're going to have to 'invest' alot of money into making the passages and whatever the heck else needs to match up.
dadeboy1
Aug 16, 2007 11:03 PM
JBirch_97Prelude
Jan 21, 2007 12:07 PM
