BUILT LS/VTEC swap with LSD for sale
located in long island ny
about 3500 miles on the build. ran 12.9 2250 lbs with driver. runs great but time for somethign better. 12.9 and it only sa mild a/f street tune, and stock cam gears. thers probly another 20 hp to be squeezed out
b16 head
skunk2 springs n retainers
skunk2 stage 2 cams
type r intake manifold
type r throttle body
jdm type r header
arp head studs
LS block
new water pump and oil pump
arp rod bolts
p30 b16 pistons
8lb flywheel
ACT 6 puck clutch only 600 miles on the new disc
y1 jdm b16 cable tranny with LSD
HASPORT EF shift linkage
HASPORT EF mounts
chipped P28 ecu
axles
will trade for a k series swap engine/tranny/ecu
asking $3500 for EVERYTHING. obd1 distributor (wit obd0 conversion plugs for obd0 harness), obd0 injectors and alternator. perfect for an EF
prefer not to, but will sell off the longblock if ur not puttin it in a EF, make offers on that or the tranny
motor is currently still in the car, if ur serious u can see the motor run, leave a deposit and we will then take it out.
Modified by JDM96SpecCTR at 12:10 AM 9/6/2006
b16 head
skunk2 stage 2 cams
jdm type r header
arp head studs
LS block
arp rod bolts
p30 b16 pistons
8lb flywheel
HASPORT EF mounts
chipped P28 ecu
axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one bad dx »</TD></TR><TR><TD CLASS="quote">How much for the lsd tranny? Whats it out of? Any trades? Let me know.
the lsd tranny would be sold for no less than 550, but would rather have the motor sold first b4 parting stuff out. its a jdm b16 cable tranny with factory lsd. no trades
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one bad dx »</TD></TR><TR><TD CLASS="quote">Alright thanks anyways homie, I need a hydro. GL on the sale.</TD></TR></TABLE>
well, they do make kits to use a cable tranny in a hydro car
