does ur headlights on your dc5 line up perfectly with the bumper or no?
Old Mar 11, 2006 | 09:43 PM
TriiiME3's Avatar
Default does ur headlights on your dc5 line up perfectly with the bumper or no?
I was just wondering if the headlights line up perfectly with the bumper and fenders bc I just noticed that my left headlight at the sharp point doesnt perfectly align with the bumper. I did take the bumper and lights out today for an HID install...can i fix that or is that normal and ok?
Old Mar 12, 2006 | 02:03 AM
silver comet's Avatar
Default Re: does ur headlights on your dc5 line up perfectly with the bumper or no? (TriiiME3)
you removed the bracket as well as the headlight. Usually after that it wont line up again. You should try fabricating/repositioning the bracket.
Old Mar 12, 2006 | 06:31 AM
Humonkuli's Avatar
Default Re: does ur headlights on your dc5 line up perfectly with the bumper or no? (silver comet)
got any pictures of how everything's positioned? In some cases the headlight will fit flushed and perfect. I recently helped my cousin install his and everything fit very well so I speak from experience.
But as Silver Comet mentioned, removing parts can also cause the headlights not to line up so making some adjustments would be the way to go. When I installed my Depo headlights I had to trim the headlight brackets so I could have more movement to adjust the headlight to where I wanted it to go. Good luck. later.
Old Mar 12, 2006 | 10:32 AM
TriiiME3's Avatar
Default Re: does ur headlights on your dc5 line up perfectly with the bumper or no? (Humonkuli)
im going to acura to check it out and ask them...
horchata
Honda Civic (2001 - 2005)
Oct 30, 2007 12:30 PM
BacardiBreezer
39
Mar 22, 2007 03:08 PM
rasta420
Nov 23, 2002 06:13 AM
tygsr
Sep 3, 2002 01:03 PM
