1990 accord speedometer
Yeah my speedometer is out, but i know it could be the VSS that is out...but could it also be something else?? loose wires?? if so where can i check to see if the wires are loose?
go to http://www.ozaccord.com go to technical form , there is a good write up on how to v.speed sensor
Yeah, The [S] light is flashing on my dash, and when i exceed speeds of 50+ MPH the Check Engine light comes on...
So how much would a speed sensor run me?
-Rob
-Rob
They usaully run between $90-$160
They have some cheap ones on ebay for like $30 bucks but it's up to you if you want to risk it working.
I have an ebay speed sensor on my 90 accord and it's been working fine for about nine months now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc »</TD></TR><TR><TD CLASS="quote">Yeah my speedometer is out, but i know it could be the VSS that is out...but could it also be something else?? loose wires?? if so where can i check to see if the wires are loose?</TD></TR></TABLE>
read this......and i would replace just the electical part , that is what causes the problem..
http://www.hondahookup.com/for...10344
i would take your current one out and inspect it make sure the gear is ok.
then try cleaning the connectors with a cotton swap and some alcohol. (worked on my civic)
if that doesnt work, try replacing the sensor portion.
Cobalt_daddy
Oct 27, 2010 10:01 PM
