Questions for ls/vtec owners.
Old Mar 11, 2006 | 07:42 PM
b20acura's Avatar
Default Questions for ls/vtec owners.
I have some questions for ls vtec owners that i need to be answered. ive been thinking about ls vtec for a while. so can you help me out and answer my questions. thnx
how long have you been running your ls vtec set up?
any serious problems?
how much did you spend on just the ls/vtec?
and what are your 1/4 mile times?
thnx
Old Mar 11, 2006 | 08:14 PM
Clutchmasta55
Guest
Posts: n/a
Default Re: Questions for ls/vtec owners. (b20acura)
i spent around $1200 or just a little bit more than that. I been running lsv for 4months now and its great. Just have a pro or someone that knows their ****. As for me i paid a friend $380 for laber and if anything breaks down he will fix it.
my set is stock 00 b16 head with stock cams, etc. and stock b18b block.
v2 intake and r-1 racing headers with apexi n1 exhaust i hit 14.7 with street tires
i knoe I could do better but that was my first time at the track. goal for next time is 13's
Old Mar 11, 2006 | 08:29 PM
90tegfrank's Avatar
IF MONEY IS AN ISSUE DON'T DO IT BECAUSE LS/VTEC IS AN AWESOME BUILD IF YOU DO IT RIGHT, AND ITS EXPENSIVE TO DO IT RIGHT. I'LL JUST SAY I HAVE 8K IN MINE.
Old Mar 11, 2006 | 08:41 PM
TurboGS-R's Avatar
Default Re: Questions for ls/vtec owners. (Clutchmasta55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clutchmasta55 &raquo;</TD></TR><TR><TD CLASS="quote">i spent around $1200 or just a little bit more than that. I been running lsv for 4months now and its great. Just have a pro or someone that knows their ****. As for me i paid a friend $380 for laber and if anything breaks down he will fix it.
i knoe I could do better but that was my first time at the track. goal for next time is 13's</TD></TR></TABLE>
Sounds good.
Old Mar 11, 2006 | 10:19 PM
ls weez's Avatar
on ur lsvtec setup did u upgrade to a vtec oil pump, and also did u use a vtec intake manofold or is it safe ta use the ls non vtec manofold?
Old Mar 11, 2006 | 10:39 PM
jdm'dc2sc61's Avatar
Default Re: Questions for ls/vtec owners. (ls weez)
i just thru an LS crank in my gsr block and voila, lsvtec. runs perfect.
Old Mar 11, 2006 | 10:46 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls weez &raquo;</TD></TR><TR><TD CLASS="quote">on ur lsvtec setup did u upgrade to a vtec oil pump, and also did u use a vtec intake manofold or is it safe ta use the ls non vtec manofold? </TD></TR></TABLE>
you gotta use the vtec manifold
my lsvtec runs fine and spins very smooth, arp rod bolts, vtec pistons and brand new oem rings are the key
Old Mar 11, 2006 | 11:01 PM
crxnj's Avatar
Default Re: Questions for ls/vtec owners. (jdmzintegra)
You should upgrade to gsr oil and water pump..And when you put on the vtec head it already has the "vtec" manifold..Do some research..
On the one I built I spent about $1000 including block and head..
B18a shortblock - $50
Acl bearings kit - $80
Arp rodbolts - $50
complete B16a head off ebay - $100
Typer cams and valvetrain - $200
gsr oil pump - $50
gsr water pump - $40
gsr timing belt - $20
new piston rings - $45
Pr3 pistons - $50
oil lines - $25
gsr arp headstuds $100
Then the rest was spent at the machine shop getting the block and head machined to fit eachother,,which you dont even have to do anymore with kits like GE lsvtec kits..
And it ran/runs good..The guy I sold the car to says its reliable like a stock motor..Its all in how you put it together,maintain it,how you drive,and the ecu tuning..
Old Mar 11, 2006 | 11:58 PM
Spectrum24x's Avatar
been running mine almost a year now, 10k miles
Runs great runs strong. but i did it right as they say,i've got around 6 grand in mine.
I screwed up and went N/A though, so im about to spend another 6 grand to tear it apart and go turbo.
Old Mar 12, 2006 | 01:55 AM
dwn2earth922's Avatar
Nobody is elaborating on the "Doing it right" part. What else is involved if you spend 6-8 grand?
Old Mar 12, 2006 | 02:57 AM
crxnj's Avatar
Default Re: (dwn2earth922)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwn2earth922 &raquo;</TD></TR><TR><TD CLASS="quote">Nobody is elaborating on the "Doing it right" part. What else is involved if you spend 6-8 grand? </TD></TR></TABLE>
Most of that money is spent at the machine shop..Im assuming iron sleeves,forged internals,decked block,milled head,built head with porting,assembly,good header,etc.All that **** adds up if you do it that way..You dont neccesarly have to do it like that though,,it all depends on your goals and your wallet..
Old Mar 12, 2006 | 09:04 AM
b20acura's Avatar
Default Re: (Mr.speaker)
thnx for all the replies.
if i do the lsvtec my friend will be doing it for me. hes been doing stuff like this for years so he knows his ****.
Old Mar 12, 2006 | 01:38 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
i been driving my ls/vtec everyday to work an back i out in 30 k on it already. the only problem that i had was a headgasket failer and broken bolts. Either then it runs nice
Mr si99
Jun 22, 2005 12:50 AM
POWERINTEGRA
Jun 19, 2004 05:18 PM
