air intake question
Old Mar 11, 2006 | 04:59 PM
slowgd3's Avatar
Default air intake question
i have a question can i just take off the box of my stock intake and stick a filter in place of it? will it mess my car up in any kind of way?
Old Mar 11, 2006 | 05:21 PM
Uncle Willie's Avatar
Default Re: air intake question (xchooex)
People have done it. I dont think that it will mess up ur motor. You may lose hp tho since your sucking up air right above ur exhaust.
Old Mar 11, 2006 | 05:26 PM
ThE PiMpiN Co's Avatar
Default Re: air intake question (RIP Indian Larry)
it wont mess up your car, just make sure you install it right with no leaks or open areas. also, reset your ecu by taking out your ecu fuse for 10 seconds and you're good.
Old Mar 11, 2006 | 05:31 PM
slowgd3's Avatar
Default Re: air intake question (aRaBiAn RiCe)
ok thanks alot
Old Mar 11, 2006 | 06:24 PM
four1one
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">People have done it. I dont think that it will mess up ur motor. You may lose hp tho since your sucking up air right above ur exhaust.</TD></TR></TABLE>
You also have to consider how restrictive the stock air box is... i dont think he will lose hp but hes probably not going to gain it ethier
Old Mar 11, 2006 | 06:49 PM
Default Re: air intake question (four1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one &raquo;</TD></TR><TR><TD CLASS="quote">
You also have to consider how restrictive the stock air box is... i dont think he will lose hp but hes probably not going to gain it ethier</TD></TR></TABLE>
Well, you also have to look at how intakes work. We all know that the stock intake is restrictive. I really dont know how to explain it, but the tubing design is how some intakes make more hp than others. For example: the password jdm and a regular sri. Both the same concept, but the design of the "Whale *****" and its big chamber somehow nets you more hp. (I dont know how to explain why; so i wont make a idiot out of myself)
Also take the AEM V2 intake and a regular CAI. The V2 has that dual chamber design which does somthing to the air flow (like a venturi in a carbureator). V2&gt;Most CAI becuase of that dual chamber design.
That is also why i think the OP MIGHT lose hp. It may make more hp than stock, it may not. I dont know.
We are pretty much debating over something that has been said many times. Any aftermarket intake on a stock honda wont produce massive gains. Once one starts modifying the internals, then a quality intake will stand for itself.
Old Mar 11, 2006 | 08:54 PM
slowgd3's Avatar
thanks
tpot90
Nov 11, 2007 04:02 PM
the king.
Mar 29, 2007 07:35 PM
kekekekevin
17
Sep 9, 2006 06:48 AM
Defcon2030
Nov 24, 2005 01:27 PM
GettaluvR
Oct 26, 2003 06:51 AM
