motor mount question
Old Mar 11, 2006 | 03:03 PM
dogbiscuit's Avatar
Default motor mount question
is it possible to reuse motor mounts? if so can you swap 96-00 civic ex mounts with a 92-95 ex mounts?
Old Mar 11, 2006 | 06:31 PM
dogbiscuit's Avatar
anybody?
Old Mar 11, 2006 | 08:03 PM
CardDealer's Avatar
Banned
Default Re: motor mount question (dogbiscuit)
Modified by CardDealer at 2:50 PM 11/16/2006
Old Mar 11, 2006 | 09:06 PM
aspec101's Avatar
driver side mount is different
Old Mar 11, 2006 | 09:37 PM
qat727's Avatar
Default Re: motor mount question (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">I dont see why you couldnt reuse them. If they're stock, they're only rubber. The upper mount is viscous, but that doesnt mean you cant reuse. Dont know about the compatability though.</TD></TR></TABLE>
not trying to threadjack here, but what year did the viscous mount come into use?
Old Mar 11, 2006 | 09:56 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: motor mount question (aspec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 &raquo;</TD></TR><TR><TD CLASS="quote">driver side mount is different</TD></TR></TABLE>
i think hes right, but just line up the bolts n see if they match..
Def check the rubber in the mounts and make sure they're not dry rotted or just worn out or anything like that
Old Mar 12, 2006 | 05:04 AM
dogbiscuit's Avatar
my reason for this question is because, i have a 1993 ex that is wrecked and i am about to buy a 99ex with a moving shifter leading me to believe a motor mount is shot.
thanks
Old Mar 12, 2006 | 12:42 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (dogbiscuit)
what do u mean a moving shifter
Old Mar 13, 2006 | 05:58 AM
dogbiscuit's Avatar
when i get on or off the gas in the 99ex the shifter will move with the motion of the motor, its not moving in or out of gear it is just moving about 1/4" in its place, as if the motor mounts are bad.
meagainsttheworld
Jul 26, 2008 10:26 AM
steveharrmr23
May 1, 2008 08:57 AM
Young Deezy Son
May 13, 2006 08:35 AM
seeeya04
Dec 14, 2005 02:41 AM
oMek
Jan 6, 2004 05:23 PM
