gsr swaped crx need help
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
im foulin plugs and my vtec kicks like im hittin my rev limiter.?ppressure plate is bad ,i have an oem fuel pressure regulator, and it says its runnin 42lbs of fuel pressure?do i need a aftermarket fuel pressure reg.? thanks
Just took it back out for a drive and its still sputtering and missing while accelerating. Kinda like a jerking and then when VTEC engages it sounds as if it hitting the rev limit. I cant figure it out? ANYTHING GUYS?????
Reset your ECU
How to do so:
Unplug Ecu
or
Take off the ecu fuse off off from the front
let it remain unplugged for about 5 seconds or so.
How to do so:
Unplug Ecu
or
