I NEED ADVICE
i just recently borrow my friend's old cheap short shifter and shifting is now very heavy. I dont want to install the stock because the gears are too far apart. can someone help me? is there a way to tune something so it becomes lighter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mackhaio5 »</TD></TR><TR><TD CLASS="quote">i just recently borrow my friend's old cheap short shifter and shifting is now very heavy. I dont want to install the stock because the gears are too far apart. can someone help me? is there a way to tune something so it becomes lighter?</TD></TR></TABLE>
I'm not sure if I understand you correctly, but a short shifter has no affect on the gearing of the transmission. Also, was the short shifter the correct part for your car?
sounds like the bolts that attach the shift linkage to the shifter are too tight.
go underneath, and loosen em up a little, should be smooth after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juice91si »</TD></TR><TR><TD CLASS="quote">sounds like the bolts that attach the shift linkage to the shifter are too tight.
Kyles ej1
14
Oct 2, 2005 09:27 PM
superbeastcrx
Sep 13, 2005 06:09 AM
