not starting, egg smell
Old Mar 11, 2006 | 11:38 AM
Black98sh's Avatar
Default not starting, egg smell
I have been having some starting issues with my car of late. It will start, but it takes quite a while. Once starts up there is a nasty egg aroma. I searched, but all the posts related to a bad cat. I'm thinking one of three causes, bad battery, bad starter, or possibly a timing belt issue(tensioner maybe). Have any of you had this problem, and if so, what was it?
Old Mar 11, 2006 | 01:06 PM
Cottonwoodz's Avatar
Default Re: not starting, egg smell (Black98sh)
Could be cheap gas
Old Mar 11, 2006 | 02:02 PM
00BLKBB6's Avatar
Bad Cat for sure. I had friends that had this problem when they had that funky egg smell,
D
Old Mar 11, 2006 | 02:45 PM
racericky's Avatar
Default Re: not starting, egg smell (00BLKBB6)
if it lags to start it is the battery for sher
Old Mar 11, 2006 | 02:49 PM
vinuneuro's Avatar
bad cat
Old Mar 11, 2006 | 03:35 PM
lude98SH's Avatar
Default Re: not starting, egg smell (vinuneuro)
Any cels ? Are u getting power to all your electronic devices ?
Old Mar 11, 2006 | 04:30 PM
classified's Avatar
100% cat
Old Mar 11, 2006 | 05:51 PM
Black98sh's Avatar
Default Re: (spirctsae)
Once the car is running there seems to be no problem. The idle tends to be a little rough at times, but it doesn't seem to be a serious issue. I'm leaning towards the battery being the issue, and I will have that checked out tomarrow. In regards to the cat, I have 76,000 miles on my prelude, could it be time for a new cat? I figured if it wasn't rattling it was ok. The smell is only evident at start up. I appreciate the advice.
Old Mar 11, 2006 | 06:00 PM
vinuneuro's Avatar
Default Re: (Black98sh)
Regardless of standard warranty, emissions warranties are diff (longer) due to fed regulations. Check what it is.
Old Mar 11, 2006 | 07:26 PM
hondamanmark's Avatar
Sounds like clogged cat.
Old Mar 11, 2006 | 07:29 PM
ShinobiLude's Avatar
Default Re: (hondamanmark)
Bad eggs = bad cat. on ANY car.
Old Mar 13, 2006 | 11:44 AM
Black98sh's Avatar
It was the battery. I guess that I could still have a bad cat, but since the battery replacement no egg smell. Thank you for all the advice.
33steviebix
10
Oct 30, 2011 08:49 AM
93_teg_CT
Nov 30, 2005 10:19 AM
89hatchback
15
Dec 11, 2003 10:06 PM
Mr. Softee
Nov 2, 2001 12:46 AM
.nate
11
Nov 1, 2001 11:28 AM
