steering column jacked up
Old Mar 11, 2006 | 09:40 AM
Dutch-VTEC's Avatar
Default steering column jacked up
My friends steering column is bent up and twisted. We are going to the junkyard to buy a new steering column. I have searched to find out how hard it would be to do. I have never done it before, but I am very confident that I could do it. Anyone ever replace theres before. I would like to have a few pointers on it or possibly a write up. Like I said before, I searched but was unable to find what I am looking for. Thanks
Old Mar 11, 2006 | 09:48 AM
Kouki-EK9's Avatar
Default Re: steering column jacked up (Dutch-VTEC)
While my motor was out I swapped my CX tranny for a SI ps one. From my experience I can say that it is a real pain in the ***. Unbolting everything is easy, getting it out is a little harder. It'll seem like it doesn't want to come out but you just have to work with it. If it's a manual steering rack it'll be easier since it has less hoses than a ps one. GL
BTW, this was on a 99 civic.
Old Mar 11, 2006 | 09:52 AM
Kouki-EK9's Avatar
Default Re: steering column jacked up (Kouki-EK9)
lol, I'm sorry. I was thinking steering rack.
Old Mar 11, 2006 | 10:29 AM
Dutch-VTEC's Avatar
Yeah, at first you had me scared, but thank god it wasn't the right thing. I am so glad I don't have to remove the rack&pinon part of it. I was wondering if all the work can be done under the dash and not have to disconnect anything from under the hood.
Old Mar 11, 2006 | 12:15 PM
Kouki-EK9's Avatar
Actually, since the steering column does connect directly to the steering rack I think I can help.
On 96-00 Civics the column can be disconnected from the rack without getting under the car at all. The rack has a rod coming out of it and the steering column kind of just clamps around it. You'll have to loosen some bolts, and I imagine after you've freed the column it will just slide off. Basically, I did the opposite by pulling the rack away from the column.
Old Mar 11, 2006 | 12:54 PM
Dutch-VTEC's Avatar
Thats kinda the answer I was looking for, thanks
Old Mar 11, 2006 | 02:41 PM
john666's Avatar
pretty easy. there is a uhhh i think 12mm you have to take out close to the floor board when u put the new column in there is a notch for it so make sure it lines up. besides that swap the wires and etc over. 1-10 probably a 3-4
Old Mar 11, 2006 | 02:45 PM
Dutch-VTEC's Avatar
Default Re: steering column jacked up (john666)
yeah, I figured it couldn't be that hard. Thanks
Paul Bisioc
Jun 25, 2019 11:29 AM
rotten
Oct 17, 2005 05:16 PM
MrTodd
Apr 10, 2005 02:59 AM
90Hatch
Nov 19, 2002 04:19 PM
