Installing S2K seats on my DC2, what is needed, as far as seat rails your to go, who sells a set up?
I have just bought a pair of S2K seats, and I wanted to know if any has done this on there Integra...I would also like to know if there is a pre-made set up for this seat swap...any help is welcomed!
u can use it...just use the s2k rail that it comes with...the fronts will bolt up..but for the rear ones u need to drill a hole thru.....then put a bolt thru it..and a nut on the other side (underneath the car) and thats it!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon »</TD></TR><TR><TD CLASS="quote">u can use it...just use the s2k rail that it comes with...the fronts will bolt up..but for the rear ones u need to drill a hole thru.....then put a bolt thru it..and a nut on the other side (underneath the car) and thats it!</TD></TR></TABLE>
the one I saw was a lot more technical and a lot more well done... meaning no new holes through the floor of your car. I would find that. before I started drilling away.
Thank Bro if you can find the site or the thread send it this way, Cause I really don't want to make holes on my car...Thanks again!
How did this sit? Iam trying to picture it and it seem like it might sit higher for some reason...I don't know I might be wrong! Anyone else have any pic's of this set up...please...
square_1
Dec 11, 2006 02:18 AM
Spoold_R
May 14, 2004 06:22 AM
