Would the D15Z1 be a good block to build off of? and Why??
Old Mar 10, 2006 | 08:15 PM
tommy.'s Avatar
Default Would the D15Z1 be a good block to build off of? and Why??
is this block any good and give ur REASONS...what would be a good block to build off of? Single cam.....
Old Mar 10, 2006 | 08:17 PM
ExCon's Avatar
Default Re: Would the D15Z1 be a good block to build off of? and Why?? (eg6b0i)
searching owns you
Old Mar 10, 2006 | 08:20 PM
tommy.'s Avatar
Default Re: Would the D15Z1 be a good block to build off of? and Why?? (NOjdmHERE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOjdmHERE &raquo;</TD></TR><TR><TD CLASS="quote">searching owns you </TD></TR></TABLE>
no it doesnt i looked already
Old Mar 10, 2006 | 08:24 PM
00siandrew's Avatar
I would say no. I know I wouldnt spend the time or money on it. If you want sohc only just boost a d16y8. That motor has more power and is just a better base to start off of.
Old Mar 11, 2006 | 12:34 AM
tommy.'s Avatar
but whats so WEK about the block?
Old Mar 11, 2006 | 12:20 PM
00siandrew's Avatar
Default Re: (eg6b0i)
The d16y8 has obviously more output, (bigger motor) and there are going to be more aftermarket parts available for it. It's just a more powerful base to start off with and finding parts for it wont be as hard.
Old Mar 12, 2006 | 11:14 PM
tommy.'s Avatar
**** it....ill jst get a b series
Old Mar 12, 2006 | 11:37 PM
Bense's Avatar
check the sig
d15z1 is an excellent starting point. within the next year I plan on building an all motor d. Guess what block I'll be using.... d15z1.
d15z1 and the jdm d15b are the ONLY d-series with a good 1.62 r/s ratio (same as b17)
Don't listen to n00bs on this site. What do they know? the only reason a d16 has more displacement (read: bigger motor) is due to it's 89mm stroke
Old Mar 13, 2006 | 09:26 PM
ExCon's Avatar
Default Re: (Bense)
doesnt a d15 have weaker rods than a d16
Old Mar 13, 2006 | 09:39 PM
Bense's Avatar
Default Re: (NOjdmHERE)
d15 rods are weak. but the d15z1 rods are stronger than normal d15 rods.
the d15z1 is a freakshow.
if it were me, I'd get a some 01-06 gx pistons and put a z6 or y8 head on the thing.
The d15z1 has a d15 crank with d16 lenght rods and shorter pistons.
Ignore the z1 head cause it's a total freakshow.
basically the d17 has a longer stroke (~95) with d16 length rods. stuffed into a block that's the same height has a d16.
CLIFF NOTES: USE PMS pistons from the 01-06 civic gx (they're like 25 bucks a piece ULTRA CHEAP!!!). along with a sohc vtec head and you'll have a good r/s ratio along with a 11.3ish cr
b16s are overrated.
Old Mar 13, 2006 | 10:12 PM
lemon_juice's Avatar
Default Re: (Bense)
are jdm d15b and d15z1 crank the same part #? and also are the vx rods the same as the d15b rods cuz i know d15b rods are the same as z6 rods.
Old Mar 13, 2006 | 10:15 PM
Bense's Avatar
Default Re: (lemon_juice)
nah, that's biggest difference in the vx/d15b.
d15z1 uses a d15 crank (d15 sized journals) and unique rods (d15 sized journal, d16 lenght)
Old Mar 13, 2006 | 10:20 PM
Default Re: (Bense)
everything is same length tho? is wrist pin location same for both?
Old Mar 13, 2006 | 10:21 PM
Bense's Avatar
yup.
I'm really wanting someone to put some PMS pistons in a d15z1 and do a mini-me with a good tune and dyno it.
Old Mar 13, 2006 | 10:36 PM
Default Re: (Bense)
yea, the vx pistons got a big dish...so the gx pistons will fir in a d15b and same cr 11.3ish right?
Old Mar 13, 2006 | 11:04 PM
Bense's Avatar
yeah, 11.28:1 with a y8 head. a little less with a z6 head
Old Mar 13, 2006 | 11:05 PM
IT'S ME DAVID's Avatar
NooB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6b0i &raquo;</TD></TR><TR><TD CLASS="quote">**** it....ill jst get a b series</TD></TR></TABLE>
.best thing you said on this thread so far,.
Old Mar 13, 2006 | 11:09 PM
Bense's Avatar
Default Re: (EJ8 DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 DAVID &raquo;</TD></TR><TR><TD CLASS="quote">.best thing you said on this thread so far,.</TD></TR></TABLE>
the more one spends on an engine swap, the less can spend on other things. To me, I'd rather have 2000 dollars than 5lbs of torque and maybe 1000more rpms.
Make no mistake, b-series are better than d-series. They will always have more hp potential. But dumbasses pay high prices for b-series. And those guys keep the prices up for everyone else. I've seen b-series distributors go for 200 dollars. Never seen a d-series go for more than 100. Seen a d16y8 tranny go for avg of 200 dollars. Seen LS trannys with grinding gears go for 450.
I bought a d15z1 swap. with no dizzy, no timing belt and no injectors for FIFTY dollars. I got a busted ex tranny for free. gear swap time. BTW, vx tranny was in imaculate shape. (long gears are good for preserving synchros and bearings ) Put some gx slugs in it (200 dollars with new rings) and add an ex head for 100 + 50 for an intake manifold + throttle body. We're now talking less than 500 dollars for a complete engine + transmission that gets from point A to point B with decent quickness. No, it's not as fast as a gsr swap. But is it really worth that extra 2000-2500 dollars? To those that don't know. It is. But to those that do, it doesn't.
Old Mar 14, 2006 | 02:42 AM
Default Re: (Bense)
just making sure, ive been reading about gx pistons but not getting clear answers that i want.
will the gx pistons bolt directly into my jdm d15b with stock rods? i read that the wrist location is good to fit in the block, but will the wrist pin diamater be the same as to no machining modification.
im realli looking foward to spening a mere 200 in pistons/rings to get my compression up from 9.4 to 11ish. also, will this be good on 92octane?
Old Mar 14, 2006 | 04:42 AM
dwnthehatch's Avatar
The D15Z1 block also has an oil cooler.
Old Mar 14, 2006 | 05:12 AM
Bense's Avatar
yes, you'll need to get it tuned though. the PDN pistons from 98-00 GX are good for d16s. but the PMS pistons from 01-06 will work (they have a 19mm wrist pin)
yeah, how about that oil cooler too
Toroke's Avatar
Default Re: (dwnthehatch)
Check this, but I've heard D15 rods are expensive and only a few companies make them (Crower comes to mind). But then again, dwnthehatch said they're different rods, so I dunno. Just suggesting. It'd be worth your while to at least look up.
Old Mar 14, 2006 | 05:15 AM
Bense's Avatar
Default Re: (Toroke)
http://www.knology.net/%7Ejediklc/pistonnotes.htm
Old Mar 14, 2006 | 05:55 AM
schardbody's Avatar
hey andrew, help me get this D15b in my car and i will do the z1 mini me.
Old Mar 14, 2006 | 05:56 AM
Bense's Avatar
Default Re: (schardbody)
help me out with the d15b crank lol
