DRL / Low Beams no longer working
Hope someone can help me....
The other day I had a dead battery and had to jump start the car.
All went well with the boost and I was able to start the Honda Accord.
When I was taking the cables off of the battery the low beams flashed on then shut off. :-(
Since then....
since then the DRL's / Low Beams along with the marker lights will not come on :-(
the high beams and turn signals still work Looking for ideas if anyone can help me I would be very appreciative this is driving me nuts (pardon the pun)
The Car....is a 1990 Honda Accord EXR with 340,000 KMS on it
Thanks for the response I meant to include I checked all the fuses except the light relay!
I do not know how much a relay costs but probably my next step.
Pjrs
Pjrs
Well, if not the fuse, I would suspect either the relay or the wiring itself. Depending on how hard it is to get to the relay, you can try a known-good one from a friend's car before you go out and buy one.
ty.s07
Dec 24, 2011 11:50 AM
natek24
Sep 12, 2008 07:28 PM
