Double Clutch
Old Mar 10, 2006 | 07:54 PM
BB2_SI's Avatar
Default Double Clutch
How many of you use this method while racing?? i understand normal double clutching, which i think is clutch out of gear release and clutch again to upshift. i dont understand how this could be good for racing. SoMEone explain please
Old Mar 10, 2006 | 08:27 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Double Clutch (1990_DA)
It has not purpose with a synchronized transmission. You can rev match on a downshift, which is useful.
Old Mar 10, 2006 | 08:35 PM
loudassVTEC's Avatar
Just something out of Fast and the Furious. Just like all the other myths...titanium valve springs, Nitrous oxide being flammable, blowing welds on the intake, green, red, and blue fire coming out of the exhaust when revving...nitrous causing massive wheel spin in 4th gear. It's all bullshit, you can't believe everything you hear in the movies. Double clutching is used to shift gears in a non-synchronized tranny. It is also used to reduce wear on synchros, or if you've worn out your synchros, you can get it in gear without grinding. Also makes for smoother, better downshifts.
Old Mar 10, 2006 | 08:42 PM
BB2_SI's Avatar
Mr. Loudassvtec how do i join the DA squad??? sorry i dident pm u im not aloud to, yet
Old Mar 10, 2006 | 08:45 PM
BB2_SI's Avatar
also thats what i thought about double clutching. i thought it made no sense in a synchro tranny. thanks for clearing that up
Old Mar 10, 2006 | 11:48 PM
FalkenSiR's Avatar
Default Re: Double Clutch (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just something out of Fast and the Furious. Just like all the other myths...titanium valve springs, Nitrous oxide being flammable, blowing welds on the intake, green, red, and blue fire coming out of the exhaust when revving...nitrous causing massive wheel spin in 4th gear. It's all bullshit, you can't believe everything you hear in the movies. Double clutching is used to shift gears in a non-synchronized tranny. It is also used to reduce wear on synchros, or if you've worn out your synchros, you can get it in gear without grinding. Also makes for smoother, better downshifts.</TD></TR></TABLE>
This is not true. Yes, our trannies have synchros and you don't need to double clutch while slowing down. BUT it dies decrease the wear on the synchros. Think about it, that's why a lot of people have problems with grinds -synchro tear and wear. If we went by what you said, then there would never be any wear on the tranny because "we have synchros." You don't need to do it, but it does help the tranny out as far as longevity goes.
Old Mar 10, 2006 | 11:55 PM
Spectrum24x's Avatar
my concept of double clutching for aggresion is this
ok your in first gear, your run it to redline, then you shift to second, say your RPMS drop to like 4000 so you slam on the clutch again, (while in gear, with the gas too the floor) then just step off it really fast, thus your motor will rev up to like 5500 or 6000 and give you a little extra boost at the beginning of your gear.
Dunno if this is considered double clutching or not, but it gives you alittle jump, and tears the **** out of your clutch.
Old Mar 10, 2006 | 11:57 PM
Default Re: Double Clutch (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
This is not true. Yes, our trannies have synchros and you don't need to double clutch while slowing down. BUT it dies decrease the wear on the synchros. Think about it, that's why a lot of people have problems with grinds -synchro tear and wear. If we went by what you said, then there would never be any wear on the tranny because "we have synchros." You don't need to do it, but it does help the tranny out as far as longevity goes.</TD></TR></TABLE>
The JDM trannies just tend to have weak *** synchros anyways...
that reminds me, i need a rebuild soonish
Old Mar 11, 2006 | 01:33 AM
1337whp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Just something out of Fast and the Furious.</TD></TR></TABLE>
almost reminds you of the "hes gana be running 3 honda civics with SPOON ENGINES!!1"
if ur gana dc then do it while daily driving since you have snychonized gear bx then its ok if you dont
Old Mar 11, 2006 | 01:36 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Double Clutch (1337whp)
dude, just be like the rest of us and granny shift
Old Mar 11, 2006 | 06:39 AM
geezer_187's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote">
almost reminds you of the "hes gana be running 3 honda civics with SPOON ENGINES!!1"</TD></TR></TABLE>
"Now me and tha mad scientists are gonna have to rip apart the block, and replace the piston rings you fried!!!!" haha
Old Mar 11, 2006 | 06:45 PM
That's what I was trying to say. You don't need to do it, and you won't be any faster if you do it, but if you do it correctly, your synchros will last a lot longer, because you basically are bypassing them when you double clutch. And yes, I can vouch for JDM tranny synchros, they suck. At least mine do. I need a new tranny soon, because I have to double clutch just to get into 3rd gear, or drop into second.
Old Mar 11, 2006 | 07:07 PM
Default Re: (1990_DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_DA &raquo;</TD></TR><TR><TD CLASS="quote">Mr. Loudassvtec how do i join the DA squad??? sorry i dident pm u im not aloud to, yet</TD></TR></TABLE>
You have to search for the DA squad thread, and ask to join.
Old Mar 11, 2006 | 07:11 PM
Uncle Willie's Avatar
Default Re: Double Clutch (Spectrum24x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x &raquo;</TD></TR><TR><TD CLASS="quote">my concept of double clutching for aggresion is this
Dunno if this is considered double clutching or not, but it gives you alittle jump, and tears the **** out of your clutch. </TD></TR></TABLE>
Why dont you just leave your foot on the gas and not let up until your done accelerating. Just leave your foot on the gas and when you shift, dont let off the gas. I think its call "speed shifting". Not sure, i remember my dad telling me about that in the old days which american muscle cars. To bad most american cars now suck.
Old Mar 12, 2006 | 07:19 AM
Default Re: Double Clutch (RIP Indian Larry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIP Indian Larry &raquo;</TD></TR><TR><TD CLASS="quote">
Why dont you just leave your foot on the gas and not let up until your done accelerating. Just leave your foot on the gas and when you shift, dont let off the gas. I think its call "speed shifting". Not sure, i remember my dad telling me about that in the old days which american muscle cars. To bad most american cars now suck.</TD></TR></TABLE>
That's the way I do it when I race. I just leave my foot to the floor the whole time. It's actually called "full-throttle shifting". I think speed shifting is when you don't use the clutch at all, you just wait till red-line, and yank the shifter into the next gear. I don't know exactly how to do this, because I'm not trying to grenade my tranny. There was this kid at the track with a stock GSR in a hatch running 7.80 in the 8th. Everytime he would shift, fire would come out the exhaust. I asked him how he shifted as fast as he did, and he told me he doesn't use the clutch, he just waits until redline, and shifts. Anyone else heard of this, or do this?
Old Mar 12, 2006 | 08:55 AM
That's the way I do it when I race. I just leave my foot to the floor the whole time. It's actually called "full-throttle shifting". I think speed shifting is when you don't use the clutch at all, you just wait till red-line, and yank the shifter into the next gear. I don't know exactly how to do this, because I'm not trying to grenade my tranny. There was this kid at the track with a stock GSR in a hatch running 7.80 in the 8th. Everytime he would shift, fire would come out the exhaust. I asked him how he shifted as fast as he did, and he told me he doesn't use the clutch, he just waits until redline, and shifts. Anyone else heard of this, or do this?</TD></TR></TABLE>
Sounds like a sure fire way to blow the tranny..
Maybe he had a tiptronic tranny er whatever =D
I'll have to try that full throttle shifting next time i hit up the track
Old Mar 12, 2006 | 10:49 AM
I'll have to try that full throttle shifting next time i hit up the track</TD></TR></TABLE>
Yeah, I dropped 2 tenths of a second at the track when I full throttle shifted last, and it wasn't a fluke. I used to run 10.2's consistantly, then I tried the full throttle shifting, and dropped to 10.0. Then I converted to obd-1, and dropped to 9.80, and I am running that consistantly.
Old Mar 12, 2006 | 10:55 AM
Lauj87's Avatar
This is called clutch kick.....i don't recommend doing this all the time wears down the clutch pretty fast..i only do it when i get a bad launch and my RPM's drop too low, or when racing from a rolling start on second.
Old Mar 12, 2006 | 11:27 AM
Yeah, I dropped 2 tenths of a second at the track when I full throttle shifted last, and it wasn't a fluke. I used to run 10.2's consistantly, then I tried the full throttle shifting, and dropped to 10.0. Then I converted to obd-1, and dropped to 9.80, and I am running that consistantly. </TD></TR></TABLE>
Is that quarter mile time? or 1/8 mile time?
Old Mar 12, 2006 | 12:11 PM
xplanetearth420x's Avatar
if u keep the gas down all u do it get mad wheel spin or i do at least
and when u dont use the clutch i just call it "power shifting"anyone agree
Old Mar 12, 2006 | 12:43 PM
Default Re: Double Clutch (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">
and when u dont use the clutch i just call it "power shifting"anyone agree</TD></TR></TABLE>
Traction bars FTW!!
Old Mar 12, 2006 | 01:23 PM
four1one
Guest
Posts: n/a
Is that quarter mile time? or 1/8 mile time?</TD></TR></TABLE>
Why would you think it was 1/4 mile?
Old Mar 12, 2006 | 01:36 PM
I wish I ran 9.80 in the quarter!! Not with 149whp though.
Old Mar 12, 2006 | 01:40 PM
I don't have enough torque to get wheelspin. Actually, when I shift normally, the clutch grabs hard, and I get a lot of wheelspin, but when I make full-throttle shifts, for some reason it doesn't even chirp the wheels. I think it is because I make full throttle shifts maybe 50rpms before rev-limit, so as soon as I put my foot on the clutch it hits rev-limiter, and before it bounces and drops 200rpm, I'm in the next gear.
Old Mar 12, 2006 | 01:43 PM
Gizzer95slowmotion's Avatar
Default Re: Double Clutch (four1one)
me and my buddies don't use the clutch in close races, we just call it rip shiftin' or rippin the F*ck out of it... It's a honda you gotta break it before it rust apart....
