JDM rain guard
Old Mar 10, 2006 | 07:32 PM
mugenmarauder's Avatar
Default JDM rain guard
Does anyone know how to put these on?
Old Mar 11, 2006 | 07:32 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: JDM rain guard (mugenmarauder)
double sided tape...?
Old Mar 11, 2006 | 07:46 AM
honda3431's Avatar
Default Re: JDM rain guard (AnthonyG2003)
good double-sided tape always works for a while Just make sure you change it if it starts getting loose.
Old Mar 11, 2006 | 12:52 PM
racericky's Avatar
if they are oem JDM they have little bracets that go through the rubber seals. you have to remove them and srcew them on
Old Mar 11, 2006 | 03:24 PM
Hex03's Avatar
3m double sided tape
Old Mar 11, 2006 | 07:10 PM
hondamanmark's Avatar
Save your paint.....dont do it tacky.....find some brackets if you can.....honda dealership....autoparts store.....
Old Mar 12, 2006 | 06:08 AM
soundbomber's Avatar
Default Re: (hondamanmark)
peel back the top of your weather stripping on the windows and then screw the brackets in. then screw the visor onto the brackets from the inside
Old Mar 13, 2006 | 12:35 PM
Default Re: (soundbomber)
I will try it that way do you happen to know if there are holes under under the weather stripping. I have all of the brackets.
Yes these are oem JDM.
Old Mar 13, 2006 | 12:37 PM
Default Re: (mugenmarauder)
yes, it is under the weather stripping. the very top strip.
Old Mar 13, 2006 | 02:31 PM
PrecisionH23a's Avatar
USDM duck tape.
put this in the cosmetic forum.
BeatDX
Feb 28, 2014 02:26 PM
JDM JON
Jun 16, 2013 07:57 AM
Jazzy Jeff 978
16
May 13, 2008 02:48 AM
Flux
May 13, 2002 08:48 PM
Nick H
Feb 13, 2002 07:41 PM
