bad starter?
Guest
Posts: n/a
Sometimes my car won't start (battery is 4 months old). The other day I had to jump start it. Today it happened agian, I turn my key to the start position but noting happen. So I decided to open up my hood and try to start it agian, to see if there's any noise. All I hear is my starting making a ticking noise. Called up a friend he came and banged on the starter and it started ever since. Do I need to replace my starter or is it good now?
thanks
thanks
My friend's hatch suddenly would die. No power, no clicking nothing. What we did was unbolt the ground from the battery (ground going to chassis) which is right by the battery and scratched the chassis surface really good and then it started fine. Just an example of how much of a bitch grounds can be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC I2aCeI2 »</TD></TR><TR><TD CLASS="quote">I went to check on my grounds and it's all rusty and old.... could that be the problem?</TD></TR></TABLE>
if they are rusty, y not just clean them while you are at it? of course that could be it but other problems can b the culprit. u need to eliminate things on ur own so we can figure out what it is. this is mostly for everyone else since this original post's owner seems to have been kicked off
sphen3p
Honda CR-V & Element
Dec 2, 2013 08:26 PM
2DoorBandit
15
Jul 20, 2011 03:54 PM
them8te
Mar 20, 2003 10:09 AM
