Drive shaft issue
im havin some driveshaft issue, on the left side of the car. i got it to go into the intermediate shaft, but then after i reinstalled everything, i looked again and it looks like it popped out of the inter. shaft. its not completely popped out, so heres my question....is it suppose to go all the way inside, or is it suppose to stick out of it? ill try to take a pic if i can...hopefully u guys get what i mean...lol..
Heres a quick pic i took:
Is all that space inbetween normal, or does it have to go all the way in..cause i tried gigglin it and it jus doesnt wana go further anymore..
Agree that it need to go further in. Did you compare the length of the old axle to the new axle? Some people have complained about some remanufactured axles not being the correct length.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Agree that it need to go further in. Did you compare the length of the old axle to the new axle? Some people have complained about some remanufactured axles not being the correct length.</TD></TR></TABLE>
No, i didnt check cause someone else picked it up for me. Ugh, i hope its not different lengths...
So i took the shaft and half shaft out, and as you can see in this pic below, where the screwdriver is pointin, thats the space im talking about. Theres no way that i can push it further into the half shaft, and i can barely get it out of there, so im guessing that it must be right, with that space in between, but id like some confirmation from a couple ppl from here, that its alright!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">the second picture you showed looks better. the first one is deceiving because of the shadow.</TD></TR></TABLE>
Are u saying better = looks right? lol
I've been thinking the same thing you have about the spacing between the halfshaft and dr. side axle. After I swapped it in, the inboard shaft of the axle wore out prematurely. I have no clue if it was due to the rebuild or the spacing between the axle and half shaft. But now, the inboard shaft can be wiggled by hand...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R »</TD></TR><TR><TD CLASS="quote">So i took the shaft and half shaft out, and as you can see in this pic below, where the screwdriver is pointin, thats the space im talking about. Theres no way that i can push it further into the half shaft, and i can barely get it out of there, so im guessing that it must be right, with that space in between, but id like some confirmation from a couple ppl from here, that its alright!
</TD></TR></TABLE>The axle sits perfectly in the intermediate shaft. You're good to go
LeeMajors19082
Oct 3, 2016 05:30 AM
Cheeech
20
Dec 22, 2005 05:55 PM
Luserkid
Sep 26, 2005 02:13 PM
