Civic proplem!
Old Mar 10, 2006 | 09:45 AM
Flamencivic98's Avatar
Default Civic proplem!
I have a 98 civic Dx engine that was back firing like crazy. I took it to a mechanic and they told me that it was the TPS sensor. So I bought a TB and put it on the civic and now it won't even start. When you turn the key I can hear the fuel pump start running but it doesn't turn over. Please help!!
Old Mar 10, 2006 | 10:15 AM
hondapowa's Avatar
maybe crankshaft position sensor?
Old Mar 10, 2006 | 11:37 AM
ZipTieGUy's Avatar
what the expletive does a tps have to do with a throttle body. get a new tps. throttle position sensor.
but its probly not that anyways. its probly your distributor
Old Mar 10, 2006 | 12:41 PM
HXvtec's Avatar
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">what the expletive does a tps have to do with a throttle body. get a new tps. throttle position sensor.
but its probly not that anyways. its probly your distributor</TD></TR></TABLE>
yep. mine did the same thing. when i changed gear to 2nd it would sound like a friggin shotgun. your timing is off.
Old Mar 10, 2006 | 02:59 PM
skiano's Avatar
Default Re: Civic proplem! (Flamencivic98)
tell your machanic he should find another profession
Old Mar 10, 2006 | 03:19 PM
schardbody's Avatar
hold on, do yo mean it wont crank/run, or do you mean the motor wont turn over??? like nothing when you hit the key???
Old Mar 10, 2006 | 03:43 PM
murmur9's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiano &raquo;</TD></TR><TR><TD CLASS="quote">tell your machanic he should find another profession</TD></TR></TABLE>
Old Mar 11, 2006 | 10:21 AM
I put a new distributor on it and got the timming done too. When I turn the key the engine won't turn over at all. thanks for all the help.
Old Mar 11, 2006 | 10:28 AM
EGwhat!!!'s Avatar
i had the same problem for me it turned out to be the internal coil. check that.
gripek
Honda S2000
12
Feb 22, 2012 10:08 PM
bizbuz45
Oct 15, 2008 10:01 AM
Ernie J
Feb 6, 2005 11:47 AM
ALLMOTOR ARUBA
Jun 6, 2004 06:16 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
