Maint Req Liight on
Old Mar 10, 2006 | 07:20 AM
DC4_MADMAN's Avatar
Default Maint Req Liight on
You are probably thinking "wow what an idiot", but its my first teg AND my first OBDII car, so I am a bit paranoid when lights I never had before go off. I am sure I just need an oil change, but just wanted to confirm.
Nothing mention in the FAQ and search didnt bring up anything.
Old Mar 10, 2006 | 07:27 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Maint Req Liight on (4door_demon)
you need to check what your mileage is, then you can look in the owners manual to see what the required maintenance is for your current mileage. Once you have completed it, or if you just are sick of the light, there is a button under your dash to turn it off. Look under the steering wheel under the dash, there is a little button just hold it in for a little bit and the light will go off!!
Old Mar 10, 2006 | 07:49 AM
DC4_MADMAN's Avatar
Default Re: Maint Req Liight on (BOLO-FTW!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOLO-FTW!! &raquo;</TD></TR><TR><TD CLASS="quote">you need to check what your mileage is, then you can look in the owners manual to see what the required maintenance is for your current mileage. Once you have completed it, or if you just are sick of the light, there is a button under your dash to turn it off. Look under the steering wheel under the dash, there is a little button just hold it in for a little bit and the light will go off!!</TD></TR></TABLE>
Thanks. I didnt get an owners manual with the car, its about to cross 96,000 miles.
iH8RICERZ's Avatar
its a blue square button btw.... also, if you typed in "maintenance light" in the search function, then clicked integra, then clicked on the archived topics, there are 51 results...all dealing with the same question.
Old Mar 10, 2006 | 07:52 AM
Lan's Avatar
Lan
Default Re: Maint Req Liight on (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">its a blue square button btw.... also, if you typed in "maintenance light" in the search function, then clicked integra, then clicked on the archived topics, there are 51 results...all dealing with the same question. </TD></TR></TABLE>
Really?? My button is square but it is white. You must have the JDM one .
Guess whos bizzack
if you dont have the book its not important anyways unless you do all the scheduled maintenance from the beginning, I checked and it just says around 97,500 you should replace engine oil and rotate tires, but obviously this wouldnt apply, so just hit the button and get rid of the light.
Old Mar 10, 2006 | 08:18 AM
DC4_MADMAN's Avatar
Wierd, I typed in "Maintenance" for the Integra forum and got nothing. Might of forgot to click archived though.
Thanks all for the help.
Old Mar 10, 2006 | 08:29 AM
juicy.fn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks all for the help. </TD></TR></TABLE>
next time you search and nothing comes up, try the ARCHIVED CONTENT. they put data in their and it wont show up if you only try recent centent.
fabalus206
Sep 18, 2006 10:29 AM
B20inDCinLBC
Jun 16, 2006 05:58 PM
escape2me
Oct 1, 2004 08:39 AM
social_control
Aug 10, 2003 04:43 PM
jonoknut
Nov 12, 2002 07:59 PM
