????Torque specs for pressure plate to flywheel bolts????
Old Mar 9, 2006 | 10:34 PM
slowrider's Avatar
Default ????Torque specs for pressure plate AND flywheel bolts????
Car: 90 civic wagon.
Motor: with a stock d15b7 (dpfi)
i need to reinstall the flywheel and pressure plate.
i need to know the torque spec for the flywheel? and the pressure plate?
Note: i did a search and i only found torque spec on the flywheel. is this ture?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02WRX &raquo;</TD></TR><TR><TD CLASS="quote">87 ft/lb on D series trannies with 6 flywheel mounting bolts
Eric</TD></TR></TABLE>
Old Mar 10, 2006 | 11:43 AM
EFworship's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (slowrider)
yeah I think that sounds right. It's been a while since I replaced the one on my '88 LX.
Old Mar 10, 2006 | 01:11 PM
jlicrx's Avatar
87 lb-ft for flywheel
19 lb-ft for pressure plate
Old Mar 10, 2006 | 04:29 PM
slowrider's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">87 lb-ft for flywheel
19 lb-ft for pressure plate</TD></TR></TABLE>
Thanks
Old Mar 10, 2006 | 04:59 PM
jacoop86's Avatar
^correct
Old Mar 10, 2006 | 06:02 PM
ACTman's Avatar
For performance applications we recommend 30 ftlbs on NEW M10.9 grade bolts. I don't trust tightening old bolts that far, but new ones won't twist off until at least 36 ftlbs. Flywheel bolts can go more than stock recommended torque too. If you are just building a stock motor there is no need though.
Old Mar 10, 2006 | 10:12 PM
Cuda70's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (ACTman)
For those bolts, I always use German torque specs..
Guten tite.
Old Mar 11, 2006 | 07:21 AM
HondaFerris's Avatar
19 lb-ft for pressure plate</TD></TR></TABLE> and some blue loctite
Old Mar 11, 2006 | 08:21 AM
Andrew Marquis's Avatar
also make sure you tighten them in a star pattern.. like you would lug-nuts on your wheels.
Old Apr 6, 2007 | 10:53 AM
steveo135's Avatar
Default Re: (Andrew Marquis)
and make sure u lube it all up because with out it the bolts wont be torqued properly
Old Sep 21, 2007 | 07:00 PM
Bob_760's Avatar
Default Re: ????Torque specs for pressure plate AND flywheel bolts???? (HondaFerris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFerris &raquo;</TD></TR><TR><TD CLASS="quote"> and some blue loctite </TD></TR></TABLE>
I've been using those torque specs and red loctite, no issues yet (and I had to take it all apart after a few thousand miles) allthough I use an impact to take it apart.
what kind of pattern do you use for 9 bolts?
t0p_sh0tta
Jun 9, 2014 10:35 AM
TeinEM2
Aug 4, 2011 07:38 AM
snzh22
Jun 13, 2008 01:06 AM
gsr18cx
Sep 7, 2004 01:04 PM
b18bVtecRS
Aug 24, 2004 03:42 PM
