gsr swap pros and cons
Old Mar 31, 2002 | 05:37 PM
ekekek's Avatar
Default gsr swap pros and cons
the search engine isnt working right now, at least for me its not.
with that said, i would like you guy to help me out. i got $4000 saved up now and i was planning on saving up for an ITR motor swap in my 96 ek HB. i want to go N/A but turbo would be fun too. anyways, what would you guys do. im not basing my choice on what anyone else does, i just want more opinions of stuff i might not have thought of yet.
im now thinking gsr for reasons of being fast and fun while i decide on N/A of FI, but my friend says get a b16 now, buy and ls block and sleeve it to 85mm.
sorry if im boring you. im sure this has been answered so refer me to another post if you can. thanx.
Old Mar 31, 2002 | 05:58 PM
owen_the_soyboy's Avatar
Default Re: gsr swap pros and cons (ekekek)
hmmm gsr vs. itr...?
pros of itr vs gsr
itr-
lsd, valvetrain, cams, intake manifold, header, valve cover ( ), port'n'polished head.
gsr-
need that **** the itr has and you gotta put it in too...
Old Mar 31, 2002 | 06:00 PM
sshaikh01's Avatar
Default Re: gsr swap pros and cons (owen_the_soyboy)
I say you get the GSR..
you will be quick enough.
Depending on how fast are you trying to go.
ITR won't be a bad idea either.
but it all depends on how fast you wanna go, and your long run plans of your car
[Modified by sshaikh01, 3:01 AM 4/1/2002]
Old Mar 31, 2002 | 06:01 PM
ekekek's Avatar
yeah, your right. i was only thinking turbo for FI purposes but ive always loved NA. thanx for the reply soyboy
Old Mar 31, 2002 | 06:03 PM
-Gambit-'s Avatar
if i were you I would go with a b20 block and a b18 head and gsr tranny.
Old Mar 31, 2002 | 06:05 PM
ekekek's Avatar
Default Re: gsr swap pros and cons (sshaikh01)
well, i know the gsr is fast enough and i only want this for street fun while i take it to the track and strip once a month, if that. turbo or NA, thats 1 ill have to figure out for myself.
thanx sshaikh01.
Old Mar 31, 2002 | 06:08 PM
ekekek's Avatar
Default Re: gsr swap pros and cons (ek9hatch)
thats a good option too ek9hatch. i would love the torque. i only womder if traction would be a problem.
Old Mar 31, 2002 | 06:10 PM
-Gambit-'s Avatar
if you want to hook up a little better get some z10 radius arms. http://www.overboost.com/story.asp?id=460
Old Mar 31, 2002 | 06:15 PM
l's Avatar
l
how fast do you want to go???
14s? 13s? 12s?
Old Mar 31, 2002 | 06:19 PM
ekekek's Avatar
Default Re: gsr swap pros and cons (IM ALL SHO)
definatly 13s. 12s would be nice but at least 13s on the street.
Old Mar 31, 2002 | 07:02 PM
C1V1C's Avatar
if you go type r you'll be in the 13's with a stock honda engine won't be hard to do with gsr either, just have to mod it a bit.
Old Mar 31, 2002 | 07:04 PM
blkwidw96's Avatar
I didn't think that for 4grand you could put together a reliable crvtec? and I thought the b16/B18C5 head were better due to their better flow designs?
Old Mar 31, 2002 | 07:12 PM
gsrvx's Avatar
New User
Default Re: gsr swap pros and cons (blkwidw96)
I think the only problem with the ITR is that it's so expensive! Aren't they $5000+ for just the changeover?? With $4000...I'd just go GSR.
-rod
Old Mar 31, 2002 | 07:20 PM
lilblacksol's Avatar
Default Re: gsr swap pros and cons (RK)
my opinion is this:
for the price of a itr you can buy a gsr and have it faster
or for the money you could do a ls/turbo set up...it does pretty good & less wiring
Old Apr 1, 2002 | 09:36 AM
ekekek's Avatar
Default Re: gsr swap pros and cons (lilblacksol)
i was thinking of ls/turbo a while ago, but for sum reason, i would rather turbo a b16 or b18c.
Old Apr 1, 2002 | 09:39 AM
BoM's Avatar
BoM
if your doing N/A get the type R
if your going forced induction get the GSR
1.8 L ownz joo
1.6
Old Apr 1, 2002 | 10:00 AM
5gen-hybrid's Avatar
New User
Can everybody post the pro's of why they chose each engine?It seems like everybody is quick to point out an engine but they don't point out why.(except for a few people).I'm just trying to help this guy get some accurate info and not just rumored sugestions.
So why b18 over b16 if your going turbo
why b18c5 over b18c1.What can be done (specifically) do the b18c1 for the same price as the b18c5 to make the b18c1 faster? etc...
Old Apr 1, 2002 | 10:02 AM
ekekek's Avatar
Default Re: gsr swap pros and cons (BoM)
yeah. wen i figure out FI or NA, those will be my options. the only problem is the b18cturbo will take longer to save for but im sure it will be worth it. thanx for the reply BoM
Old Apr 1, 2002 | 10:39 AM
gsrhatch530's Avatar
GSR, It isn't that hard to get traction. All you have to is learn how to drive your car with the new motor and you will have no problem hooking up.
Build your car to suit yourself, not other people. LOL!
Old Apr 1, 2002 | 10:48 AM
ekekek's Avatar
Default Re: gsr swap pros and cons (gsrhatch530)
i know. im just talking this over with my HT homies learning the pros and cons. the more knowledge i have, the easier it will be to make my decission. thanx for your input though.
Old Apr 1, 2002 | 11:40 AM
BoM's Avatar
BoM
b18 over b16 why? because of torque
that extra .2 L is going to give tons more torque when u have a turbo (FI) on it
or when u put bigger cams (N/A)
more displacement more potential for power. 1.8
Type R swaps go for 4k+ - i've seen $5k full changeovers too.
GSR's will go for 3k-4k
Type R's have the advantage N/A wise, it has the perfect start outta the box
goto the type R forum, u'll see that the majority of them are N/A peeps
with a buncha bolt on's, u can see 13's with ez
you can get 12's without upgrading to hi compression pistons also just with some cams and tuning.
GSR - has a lower compression then the R motor, turbo friendly and its just the best engine overall. you can spray nos, supercharge it, turbo it, run allmotor
it'll just cost more. the tranny also is lenient, it isn't as short as the R tranny.
these are just ez pro's and cons'
the bottom line is pricing, the best bang for the buck is the GSR
well...also the LS, but were talking about VTEC motors here.
Old Apr 1, 2002 | 11:48 AM
ekekek's Avatar
im ganna save for the R.
damn. last month i was on here asking about b16 or b18c. now its itr or turbo. were am i getting this money.
anyways, thanx for all the input
Old Apr 1, 2002 | 06:12 PM
karmannghia's Avatar
Here's my set up. 3000 for GSR first then 2600 for Drag 3 = 5600 bucks and put out 240 hp at the wheel at 7psi.
[Modified by karmannghia, 3:13 AM 4/2/2002]
Old Apr 1, 2002 | 06:54 PM
BoM's Avatar
BoM
Default Re: gsr swap pros and cons (karmannghia)
gj the fastest way to POWER~ turbo!
Old Apr 1, 2002 | 08:53 PM
Tyson Ballou's Avatar
Get a jdm b16, preferably obd1 , and sleeve to 2.0L specs. better then b20vtec.. and probably cost a lil less to make it run right.
