H22 swap....Please help
Old Mar 9, 2006 | 07:31 PM
jdm_h22power's Avatar
Default H22 swap....Please help
i just swap an h22a motor into a 97 hatchback. Everything is in, hasport harness, mount, obd2a to obd1 adapter and everything. However, the car starts up fine and we drove it for like half the block and then the car just won't move forward. It can back up but when we put it in 1st, the rpm move up but the car just sit there. What can be the problem? Please help. Thanks
Old Mar 9, 2006 | 07:37 PM
stuff215's Avatar
could be synchros
Old Mar 9, 2006 | 09:23 PM
O RLY's Avatar
Default Re: (stuff215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stuff215 &raquo;</TD></TR><TR><TD CLASS="quote">could be synchros</TD></TR></TABLE>
No.
Edit...sorry I misread...could be the syncros. What about 3rd gear? Try pulling out in 3rd. If you can, its either syncros or a shift fork, if not check the linkage.
Hybrid96EK's Avatar
Default Re: (O RLY)
One of the axles pop out of the tranny by any chance?
Old Mar 9, 2006 | 09:27 PM
Turbo_y8's Avatar
Default Re: (Hybrid93Eg)
sounds like a shift linkage issue
Old Mar 9, 2006 | 09:31 PM
Hybrid96EK's Avatar
Default Re: (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a shift linkage issue</TD></TR></TABLE>
Could be. H22 uses cables though, no "linkage" like the standard B/D series. I suppose he could have a cable routed wrong to where maybe its binding and not engaging the gear correctly. Would be more likely then the popped out axle I suggested.
Old Mar 9, 2006 | 09:32 PM
Turbo_y8's Avatar
well yea its assumed
do you have the whole shifter assembly in correctly?
Old Mar 9, 2006 | 09:33 PM
turboed96LShatch's Avatar
this is weird but ive seen it.. if u have tried all the forward gears and it wont move then its a internal problem on a "input gear". its most likely striped... if its just 1st gear then its linkage.
mcc361
Sep 4, 2007 12:38 AM
littlegreenb18
15
Jun 4, 2006 08:00 AM
Al-sonic
May 4, 2006 08:06 AM
JDMCRXTypeR
17
Oct 30, 2004 11:09 AM
EATIN UP UR BSERIES
Jun 13, 2004 12:24 AM
