how to fix abs code 11 and 81 for 98 integra
Old Mar 9, 2006 | 05:04 PM
KillaB18's Avatar
Default how to fix abs code 11 and 81 for 98 integra
ok i think i ran the codes right and this is what i got. code 11(long-short) and i got code 81(long-long-long-long-long-long-long-long-short)
code 11-open circuit on front right wheel sensor. anyone have a pic of where it is?
code 81-cpu. where is that located and how much do they run?? thanx
Old Mar 9, 2006 | 09:04 PM
KillaB18's Avatar
come one someone needs to know. i did a search and couldnt find what i needed.
Old Mar 9, 2006 | 10:09 PM
mattcivic's Avatar
Default Re: (KillaB18)
the sensor is mounted on your right hub and the cpu is i believe the box behind your pas side rear quarter panel just in front of the speaker. im just guesing but it sounds like the sensor is not lined up or bad and maybe that cpu is bad? i have the cpu out of my 96 gsr if they are the same and u need it make me an offer.
Old Mar 13, 2006 | 07:56 PM
YEABOY's Avatar
Default Re: (mattcivic)
the 96 ECU wont fit on the 98. there diferent plugs. 96 and 97 are the same. 98 and 01 are the same.
Old Mar 13, 2006 | 07:58 PM
YEABOY's Avatar
Default Re: (Integ4Life)
try reseting your codes. if it comes back or doesnt even go away, you need to change those things, or repair
zcmotor
Oct 6, 2013 06:38 PM
fassassin
Jan 8, 2005 05:17 PM
smkngsr
Nov 1, 2001 06:00 AM
