Replacing the Door Handle and/or Handle Mechanism
Old Mar 9, 2006 | 04:40 PM
JoePSI's Avatar
Default Replacing the Door Handle and/or Handle Mechanism
I broke the actual plastic handle off my door (The part you lift when opening the door). Do i have to buy a whole new door, whole mechanism or just the handle? Thanks!
Old Mar 9, 2006 | 04:51 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Replacing the Door Handle and/or Handle Mechanism (LeftLaneDC2)
You can just purchase the handle, and if it's not damaged, you can reuse the lock cylinder. Keep the window rolled up and remove your door panel. Take a look inside there, and it's pretty self explanatory on how to remove the door handle piece. You may need some C-clip pliers to get at the cylinder.
Old Mar 9, 2006 | 04:58 PM
JoePSI's Avatar
Default Re: Replacing the Door Handle and/or Handle Mechanism (shamoo)
Is the lock cylinder interchangable. Say i want to put my lock cylinder into a new door handle. That should work fine correct? I dont see a reason why it wouldnt.
Old Mar 9, 2006 | 05:00 PM
shamoo's Avatar
Yes you can. You need some C-clip pliers to remove the locking cylinder (or some small hands, some small tools and lots of patience). You should be able to put that into any Honda handle (as long as it fits for that model).
Old Mar 9, 2006 | 05:57 PM
JoePSI's Avatar
Thanks Shamoo.
Old Mar 9, 2006 | 07:23 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Search for rear sedan doors, i did a DIY on how to install rear door handles to the front.
Which im sure can help you out. You can order some new handles through the dealership even same color and everything. takes about 25 minutes to install each one.
Old Mar 10, 2006 | 06:14 AM
Chriz's Avatar
Default Re: Replacing the Door Handle and/or Handle Mechanism (00IntegrAllmotoR)
damnnn foreal joe me too....my passenger interior handle broke
ogorek
Honda Civic (2006 - 2015)
Oct 17, 2015 05:59 AM
erikiksaz1
Jul 22, 2013 01:26 PM
mighty_sol
Honda Fit
Jan 1, 2011 12:43 PM
cdagza
Honda Civic (2001 - 2005)
May 3, 2006 06:17 PM
CaptivaBlue
Mar 12, 2005 04:16 PM
