Honda S2000 Honda S2000
RE: Valves?
Old Mar 9, 2006 | 02:46 PM
CaymanNational's Avatar
Default RE: Valves?
Ok, have the engine TDC...checked the clearance on the lifters..but here is the issue. the first lobe, the feeler gauge fits under (0.009) then i go to put it under the second lobe, and it wont fit under, not even (0.005) would fit under, and so on and so on with the others. Could this be the reason that there is a slight knock, because the lifters are to tight?
please let me know asap...
thanks in advance
Old Mar 9, 2006 | 03:37 PM
LBBP R's Avatar
Default Re: Valves? (CaymanNational)
huh? second lube???
ur suppose to measure between rocker & cam
Old Mar 9, 2006 | 07:28 PM
Default Re: Valves? (LBBP R)
yes i know how to measure it. just wondering if that could be why it's knocking.
Old Mar 9, 2006 | 07:32 PM
WowOzYouRock's Avatar
JDM S2000 has different measurements ROFL
Old Mar 9, 2006 | 07:47 PM
Default Re: Valves? (Honda-Tech-Jerk)
it's not different, it has the same measurements
B18ls*RAYON
Honda S2000
72
Feb 11, 2019 05:24 PM
fastegg03
Jan 24, 2009 11:48 PM
dr juice164
Honda S2000
31
Mar 1, 2008 02:08 PM
90_EX_Civic
Jan 27, 2008 05:25 AM
tegasaurus
Jul 23, 2003 06:08 PM
