i have a zc motor in my 89 crx si the wiring harness is the si the plug are different
Old Mar 9, 2006 | 01:37 PM
h22_crx's Avatar
Default i have a zc motor in my 89 crx si the wiring harness is the si the plug are different
i had a post up like 3-4 weeks back. I need the order of the pins so i can put the zc distrbutor on the si harness. help
i know you can repin them i just dont know the order of the pins
Old Mar 9, 2006 | 01:48 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: i have a zc motor in my 89 crx si the wiring harness is the si the plug are different (h22_crx)
this link won't work so just copy and paste it into your browser
http://www.angelfire.com/dc/ig...s.jpg
Old Mar 9, 2006 | 01:52 PM
jlicrx's Avatar
where it says blue, it should be blue with green stripe - just match colors at both sides of connector
Old Mar 9, 2006 | 02:24 PM
h22_crx's Avatar
Default Re: i have a zc motor in my 89 crx si the wiring harness is the si the plug are different (jlicrx)
thanks guys
Old Mar 9, 2006 | 02:38 PM
h22_crx's Avatar
i have a problem the problem is that the distributor has 5 wires the zc distributor the harness has 7
Old Mar 9, 2006 | 02:46 PM
jlicrx's Avatar
you need to put the 5-wire connector on the Si harness - wires go like in the pictures
Old Mar 9, 2006 | 02:58 PM
h22_crx's Avatar
i will try it
Old Mar 9, 2006 | 03:34 PM
Rywire's Avatar
where it says "to zc cam sensor" it says #1 blue... It needs to read blue/green
same goes for the "blue" on the si connector... this may cause issues
Old Mar 9, 2006 | 04:16 PM
h22_crx's Avatar
Default Re: i have a zc motor in my 89 crx si the wiring harness is the si the plug are different (droppedcr
help
Old Mar 9, 2006 | 04:23 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">where it says "to zc cam sensor" it says #1 blue... It needs to read blue/green
same goes for the "blue" on the si connector... this may cause issues</TD></TR></TABLE>
i believe i said that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote"> where it says blue, it should be blue with green stripe - just match colors at both sides of connector</TD></TR></TABLE>
Old Mar 9, 2006 | 04:32 PM
h22_crx's Avatar
i tryed the si way
Old Mar 9, 2006 | 11:49 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">i believe i said that</TD></TR></TABLE> I really should read better
redwards
May 29, 2007 06:44 PM
SC-MK1
May 22, 2005 08:51 PM
dra600n
Aug 27, 2003 11:26 AM
